what offset wheel for 01 type-r?
Old Feb 10, 2007 | 04:48 PM
92integra-R's Avatar
Default what offset wheel for 01 type-r?
i was thinkin about putting some 17's on my DA with the 5 lug type-r swap, anyone have suggestion for the wheel offset i need? i just got some rims from a buddy but i think they are gonna stick out. they came off new 5lug civic Hb si. what offset would someone use if buying wheels for 01 type-r?
Old Feb 10, 2007 | 04:51 PM
LunchboxZT's Avatar
Default Re: what offset wheel for 01 type-r? (92integra-R)
I believe the factory offset for Type R wheels is +45
Old Feb 10, 2007 | 05:05 PM
OG undercover's Avatar
Default Re: what offset wheel for 01 type-r? (LunchboxZT)
50
Old Feb 10, 2007 | 05:45 PM
LunchboxZT's Avatar
Default Re: what offset wheel for 01 type-r? (Mike Hancho)
hehe.
Old Feb 10, 2007 | 06:18 PM
Ill Mitch's Avatar
i have +33, little wide, rubs under fast cornering, but i LOVE how it looks
Old Feb 10, 2007 | 06:26 PM
LunchboxZT's Avatar
Default Re: (Ill Mitch)
Hmm, got any pics? I'd like to see it. And what tires are you running with those wheels?
Old Feb 10, 2007 | 06:39 PM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LunchboxZT &raquo;</TD></TR><TR><TD CLASS="quote">I believe the factory offset for Type R wheels is +45</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ill Mitch &raquo;</TD></TR><TR><TD CLASS="quote">i have +33, little wide, rubs under fast cornering, but i LOVE how it looks</TD></TR></TABLE>
Just saying an offset is not only going to throw this guy off, but its also misinformation.
Offset and wheel width go hand in hand. Play around with this http://www.1010tires.com/WheelOffsetCalculator.asp
So sure, the USDM ITR offset is +50, but its also only 6" wide.
Old Feb 10, 2007 | 06:41 PM
grjp1988's Avatar
The factory offset is 48 directional dont let anyone tell you different
Old Feb 10, 2007 | 07:06 PM
Default Re: what offset wheel for 01 type-r? (KOALA YUMMIES)
these rims came off a brand new HB si that is 5 lug. they are buddy club rims 17x7.5. with 215/40/17 on them right now. im gonna use some new 205/40/17. i'll post pics as soon as its daytime. 48 directional, what way is that?
Old Feb 10, 2007 | 07:24 PM
Default Re: (grjp1988)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">The factory offset is 48 directional dont let anyone tell you different</TD></TR></TABLE>
REALLY? <U>Prove it then.</U>
Old Feb 10, 2007 | 07:29 PM
jetydosa's Avatar
25 Year Member
The factory offset is 50. Not sure what you mean by directional.
Old Feb 10, 2007 | 07:32 PM
LunchboxZT's Avatar
Default Re: (Mike Hancho)
Hmm.. 17"s on a DA, I'm not feelin it
Now, JDM Type R 16"s on your R swapped DA would be baller
Old Feb 10, 2007 | 11:16 PM
grjp1988's Avatar
Well the guy i baught my r said he just got new tires and they were 48 directional and he said 52's would not work im not sure bout 50's but he said 48 fit the best on the stock itr wheels..
Old Feb 11, 2007 | 03:34 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">Well the guy i baught my r said he just got new tires and they were 48 directional and he said 52's would not work im not sure bout 50's but he said 48 fit the best on the stock itr wheels.. </TD></TR></TABLE>
Re-read the post above from KOALA YUMMIES. As he correctly notes, stating the offset is meaningless unless you also state the wheel width. That's because the offset only tells how far off the wheel's center line is from the surface where the wheel mounts to the hub. If the wheel is wider, you may need to re-position the center line (change the offset from stock) because you have a lot more room in the wheel well to handle the additional width on one side (the outside or the inside) than the other.
Old Feb 11, 2007 | 04:03 AM
grjp1988's Avatar
well go look at my wheel and tell me how much you love them k.
Old Feb 11, 2007 | 06:10 AM
see, it looks like its already sticking out. and that with no brakes on it!
Old Feb 11, 2007 | 06:27 AM
crxgator's Avatar
that doesnt make any sense...you cant change the offset of a rim...a rim is casted to its offset by the factory. you can change how it sits by a spacer...a tire doesnt change the offset either, i never heard of a 48, 52 however...what part of the size are you talking about?
Old Feb 11, 2007 | 06:29 AM
crxgator's Avatar
original poster did you swap out your knuckles for itr ones, or did you do it the correct way and swap over the hub to your stock DA knuckle?
Old Feb 11, 2007 | 06:36 AM
Default Re: what offset wheel for 01 type-r? (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">original poster did you swap out your knuckles for itr ones, or did you do it the correct way and swap over the hub to your stock DA knuckle?</TD></TR></TABLE>
i bought aftermarket axles and had them use type-r hubs that where turned down to fit a DA. so im pretty sure thats the same as using stock type-r hubs. they wouldnt work with new axles.
Old Feb 11, 2007 | 06:39 AM
crxgator's Avatar
ok you did it the correct way...however i really dont think you should be worried about ITR's offset since you drive a DA. your stock offset is what matters. from the looks of the pics it will probably stick out a bit, but since you are probably lowered you wouldnt be able to tell due to negative camber bringing the upper part of the tire inside...
Old Feb 11, 2007 | 06:56 AM
yeah, i put some rims and tires on the back and set it down on the ground. the front looks a lil better. but it still looks like its gonn astick out some. keep in mind theres no rotor between the hub and wheel.
edit: i think im just gonna try and give these wheels back to guy i bought them from, and get my money back.
Old Feb 11, 2007 | 07:33 AM
jetydosa's Avatar
25 Year Member
Tires do not have offset. Not sure what the hell you are talking about here?
Old Feb 11, 2007 | 08:47 AM
hayabusa160's Avatar
Default Re: (jetydosa)
i got 5 lug on my eg heres some wheels i had my hands on
16x7 0 offset hahaha
16x8 20 offset
its doable
my uncles itr with 16x7 42 offset 205 45 16
15x7 35 offset with 205 50 15 azenis rt615
Old Apr 17, 2007 | 10:31 AM
Wraith_G2IC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">however i really dont think you should be worried about ITR's offset since you drive a DA. your stock offset is what matters. </TD></TR></TABLE>
It might be worth noting that the ITR hub sticks out from the knuckle 5mm more than the stock hub. Not a huge amount, but should still be factored in.
I mention this because I too have thought "what would be the best offset to go with on my DA with 16x7, 5x114.3 wheel?"
Old Apr 17, 2007 | 11:25 AM
tONE.steR's Avatar
* B A N N E D *
Default Re: what offset wheel for 01 type-r? (Wraith_G2IC)
16x8 +32 offset all the way around w/ 215/45/16 RT615's
yoorang
Mar 29, 2008 07:53 AM
luckyfish1
Mar 25, 2006 05:28 AM
s2kc's
Honda S2000
61
Dec 29, 2005 12:26 PM
130R
14
May 31, 2005 10:38 AM
terd ferguson
Feb 26, 2004 12:07 PM
