missing gasket between brake booster and master cylinder? Is there one?
Old Feb 10, 2007 | 02:34 PM
zzsql's Avatar
Default missing gasket between brake booster and master cylinder? Is there one?
http://madlinux.com/no-gasket.jpg
The idiots at my local honda dealer/service center worked on my 1994 honda prelude.
They said the master cylinder needed replacing AND they forgot to put the gasket between the master cylinder and brake booster but I'm not sure if there's supposed to be one.
Is there?
Obviously something is missing because when I turn the vehicle off I hear a hissing sound coming from there. (I poured some water on it to determine where the leak was.)
Anyhow, does anyone know for sure if there's a gasket between these two. If so, is it supposed to go against the firewall where you could see it with it still bolted on or is it recessed further inside the hole?
Thanks
greg
ft bragg, nc
Old Nov 14, 2007 | 03:07 AM
dannydos's Avatar
Default Re: missing gasket between brake booster and master cylinder? Is there one? (zzsql)
bumpin this.....is there a gasket there...i have air coming from that area
Old Nov 14, 2007 | 06:05 AM
BlackTOY's Avatar
I dont think its supposed to be sticking out like that
Old Nov 14, 2007 | 08:38 AM
Hawkze_2.3's Avatar
Uh...the master cylinder is a sealed unit for brake fluid, and the booster is also a sealed unit just for air. There's no tranfer of anything between them so why would there need to be a gasket.
They may have been playing a joke on you
Bipolarcivic
Sep 16, 2013 09:09 AM
zeb1117
Jan 14, 2010 06:48 PM
kte324
Dec 7, 2009 05:00 PM
starsxburn
Nov 17, 2007 04:44 PM
