out 94 civic trailing arm bushes
Old Feb 10, 2007 | 12:30 PM
stevenjen's Avatar
Default out 94 civic trailing arm bushes
anyone got any ideas how to push out the old bushes? I want to do this without removing the arm from the car, just hinge it down. Its what tools to use that I need to know please.
Old Feb 10, 2007 | 02:01 PM
dr_latino999's Avatar
Default Re: out 94 civic trailing arm bushes (stevenjen)
The tool you need to do what you are asking is this -->
It's about 170 - 180$ new depending on your source.
Old Feb 10, 2007 | 02:15 PM
vtec4lyfe's Avatar
Default Re: out 94 civic trailing arm bushes (dr_latino999)
Replacement
This suspension manual will be helpful: Suspension
The rear trailing bushes are the largest and are two of the most important suspension bushes on your car. The DA Integra is becoming old and it is likely the factory rubber bushes will have worn out and may have even broken free to move within the bush. Unlike most of the installations on this website, suspension modifications may affect the safety of yourself, pedestrians and other road users so if you are not confident in your mechanical ability you should leave it to a professional.
You do not necessarily have to remove the rear trailing arms, if you have a hoist or can get the car high enough you may be able to hammer them out. It will still be difficult to get the new bushes in so you may have to devise some other method.
The replacement rubber bushes from Honda are expensive and you will probably find it is cheaper to buy aftermarket urethane bushes. The bushes I chose are Superpro urethane bushes made in Australia. They require you to reuse the factory steel tube to bolt to the bottom of the car, rather then other brands which have an integrated tube held by circlips. I chose this brand because it was relatively inexpensive for a small amount of extra work, and are well designed and built.
Removing the trailing arms
You will need
*Chocks
*Jack stands
*Jack
*10mm, 12mm, 14mm, 17mm sockets
*Pliers
Park the car and chock the front wheels since you'll be raising the rear. Loosen the wheel nuts then jack up the back of the car and put it on jack stands. Remove both rear wheels.
Remove the brake shield by removing the two 10mm bolts. Then remove the handbrake cable by removing the two bolts and removing the wire clip and the pin from the end of the cable. The cable can be removed from the bracket by removing the metal clip holding the cable in, then you can pull it out through the hole in the trailing arm. Remove the cable from the trailing arm by removing the 10mm bracket bolt.
Remove the caliper by removing the two 12mm caliper bolts, do not remove the brake line but remove the 12mm bolts holding the brake line to the trailing arm.
Now remove either of the LCA bolts holding it to the car ( I removed the LCA along with the RTA since it was easier to reach the bolt but you can leave it on the car.) Remove the 14mm shock bolt, sway bar bolt and upper control arm bolt.
Remove the 14mm compensator arm bolt holding the rear trailing arm to the car, located at the front of the RTA. Remove the two 17mm bolts holding the RTA bushes to the bottom of the car, you can now remove the rear trailing arm. Repeat for the other side.
Bushing replacement
With the trailing arms removed you can now take them into a suspension workshop and have the bushes professionally installed if you like. If you want to continue grab a blow torch and read on.
You will need
*Blow torch (oxy-acetylene torch)
*Sandpaper or buffer
*Large hose clamp or 2 to join together
*Grease (probably supplied with the bush)
* Press or Vice and a couple of flat bits of steel
*Screwdriver
Use the blow torch to heat the area around the outside of the bush, this will eventually break the bond between the bush and the steel shell. Do not heat it too hot or you may ruin or warp something. Once you see it start to go push it out with a screwdriver or something. Alternatively you may be able to use a lathe or a dremel to remove the bush, I haven't tried this. Now heat the tube until the rubber strips off this also, use sandpaper or a buffer to tidy up the outside of the tube and the inside of the shell.
Now it is time to install the new bushes. You must remember to GREASE the outside of the tube and the inside of the shell as well as the outside and inside of the bush. Apply plenty.
If you have a press you can go ahead and press the bushes in. If you're using a Vice like me you'll find it difficult to get the bush to slide in and will find the bush spinning around slightly. I used a hose clamp to squeeze one side of the bush, once you get it started take the hose clamp off and re-grease . You can now pop the bush into position by hand. To install the tube I found it best to insert it and push the whole RTA onto it on the ground. Make sure it is all greased and insert the tube AFTER installing the bush to make it easier.
Replace the trailing arms in reverse order from removal. Make sure you replace everything properly and use a torque wrench. Replace the bolts and wheels and lower the car to the ground BEFORE tightening the LCA, UCA, RTA, compensator, sway bar and shock bolts to prevent wearing other bushes out.
Old Feb 10, 2007 | 02:21 PM
Default Re: out 94 civic trailing arm bushes (vtec4lyfe)
The way you posted works if you can't afford the tool I posted or if you have a press laying about. Also, a little bit of misinformation is present.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe &raquo;</TD></TR><TR><TD CLASS="quote"> The replacement rubber bushes from Honda are expensive and you will probably find it is cheaper to buy aftermarket urethane bushes</TD></TR></TABLE> The Honda pieces are only 25.17$ a side, and aftermarket bushings constrict the ability of the trailing arm to dynamically move as the factory intended.
Old Feb 11, 2007 | 02:45 PM
Vitesse's Avatar
Skywaytools!.. Worked on my DC, saves a **** load of money and time. Prothanes will be stiffer tho. GL.
94vex
Feb 11, 2019 11:53 AM
suspendedHatch
Suspension & Brakes
Apr 18, 2006 09:27 PM
erebunicrx
10
Mar 12, 2005 06:45 PM
juniordc2
Nov 4, 2003 05:31 PM
scratchline20
10
Apr 30, 2003 09:00 PM
