help me help me b16a swap has hit a fork in the road.
Old May 19, 2002 | 07:33 AM
slowpokesi's Avatar
Default help me help me b16a swap has hit a fork in the road.
alright, i have my motor i have everything planned out except for air conditioning, i need a solution, i live in texas and i cant go with out ac. that being said i really dont want to spen 200 for a simple bracket.... out all the people with hybrid swaps on here what can i do?
also my motor has an air compressor on it, do i use mine or that one?
Old May 19, 2002 | 07:44 AM
Blown90hatcH's Avatar
Default Re: help me help me b16a swap has hit a fork in the road. (slowpokesi)
You can use the B16a AC compressor, but you will have to get new lines bent. You can use the Pr3 bracket, but you will have to redrill some holes to make the compressor bolt to it. If you can find a PWO ac bracket, you can get 2 bolts to line up with that one.
Old May 19, 2002 | 08:16 AM
slowpokesi's Avatar
Default Re: help me help me b16a swap has hit a fork in the road. (Blown90hatcH)
wich car does the pwo bracket come on?
Old May 19, 2002 | 07:30 PM
slowpokesi's Avatar
hello, guys i need more help than this,
how do i stop my frreon from leaking?
Old May 19, 2002 | 10:01 PM
89 CRX SI's Avatar
Duct tape..... J/K no i donno but i want to know too. BTW you live in OK or did you move??
Im moving to commerce texas outside of dallas next year and im going to need to switch my canadian heater for the AC unit some day.........
Old May 20, 2002 | 04:13 AM
slowpokesi's Avatar
also what wiring changes am i going to be making???
knock sensor
vtec solenoid
o2 sensor
what is the 4th one? oil pressure?
h3lp me
Old May 20, 2002 | 04:35 AM
ricodemus's Avatar
yep.
Old May 20, 2002 | 05:06 AM
slowpokesi's Avatar
Default Re: help me help me b16a swap has hit a fork in the road. (ricodemus)
any insight on ac brackets?
Old May 20, 2002 | 05:14 AM
spettinger's Avatar
what parts do you have now? i just got my jdm b16, has the bracket but no compressor.
Old May 20, 2002 | 05:15 AM
slowpokesi's Avatar
Default Re: help me help me b16a swap has hit a fork in the road. (wreckedhatch)
mine came with the b16a bracket, and b16a compressor,
Old May 20, 2002 | 12:49 PM
slowpokesi's Avatar
to the top
Old May 20, 2002 | 12:53 PM
DJ KrunchyKracker's Avatar
ummm... you said your freon is leakin. u r aware thats not real safe rite. im not sure how to stop it but i wouldnt touch it or smell it.
Old May 20, 2002 | 06:13 PM
slowpokesi's Avatar
Default Re: help me help me b16a swap has hit a fork in the road. (TheRZA28)
no i didnt say that numbnutz, i meant it as how would i stop my freon from leaking if i disconnect the ac compressor.
Old May 20, 2002 | 06:27 PM
Griffins_Importuning's Avatar
I am swapping out the hf engine for the b16 also. im not sure if i want to keep air cond. in or take it out. I live in PA so i really dont have to have it...What are your suggestions. And i need to disconnect the refrigerant lines..but when i went to take them out. it started leaking frion--im guessing...should i just bleed the lines out and go inside.....thanks for the help..
Old May 21, 2002 | 04:28 AM
civicwagonman's Avatar
Default Re: help me help me b16a swap has hit a fork in the road. (Griffins_Importuning)
check ot this ebay auction. one bracker going off. http://cgi.ebay.com/ebaymotors/ws/eB...ndexURL=0&rd=1
Old May 21, 2002 | 04:52 AM
SpooN Man's Avatar
you can't stop it from leaking. I would suggest to place a few rags over the bolt that holds the lines in, and then pull the bolt. You will hear it start to leak. Just do it outside and don't inhale it, or touch it
Lok1
Jul 26, 2018 09:01 AM
Zaakro
Nov 12, 2005 04:34 PM
davken1102
Mar 18, 2004 09:52 PM
unabonger
13
Jan 11, 2003 05:48 AM
