Pilot bearing wont fit my exedy flywheel???
Old Feb 10, 2007 | 10:57 AM
ahemming06's Avatar
Default Pilot bearing wont fit my exedy flywheel???
My car is in a tranny shop and they told me that the pilot bearing that came with the daiken OEM clutch kit will not fit my exedy lightweight flywheel.
They said I need to find a part number for a smaller pilot bearing that will fit the flywheel. I have tried searching everything and I can not find a pilot bearing part number from exedy.
Can anyone out there be my miracle and help me out with what I need to do to fix this problem? I have no idea where to look to get this right pilot bearing.
Old Feb 10, 2007 | 10:59 AM
9200RPM's Avatar
Default Re: Pilot bearing wont fit my exedy flywheel??? (ahemming06)
your replacing the flywheel and not the clutch??? save some money and swap the clutch while your in there...is the flywheel for the right year gsr motor??
Old Feb 10, 2007 | 11:55 AM
Brick Top's Avatar
my b series exedy flywheel fits the oem size bearing. the d series should be the same too. i hope the guy knows it needs to be pressed in.
Modified by brick top at 4:06 PM 2/10/2007
Old Feb 10, 2007 | 11:59 AM
bmoua's Avatar
call up exedy and see what they say? or ask another mechanic shop?
rick_rabies
Jun 12, 2013 01:33 PM
raidacaipo
May 9, 2009 07:21 PM
jdeemseerx
Oct 4, 2007 05:27 PM
jadugartir
Nov 22, 2006 10:07 AM
