Timing Assembly...Crank Gear?
Old Feb 10, 2007 | 08:58 AM
Whalesac's Avatar
Default Timing Assembly...Crank Gear?
Hey guys/gals. I don't own a civic, but what I need to know is where can I find a new crank gear for a B-Series motor. I searched Google, Advanceautoparts, and eBay and haven't come up with anything. I own a GM Quad4/Twin Cam hybrid and have been thinking of ways to run a timing belt, since we have timing chains. Plus you guys have the benefit of adjustable cam gears. We are VERY LIMITED on aftermarket parts compared to you guys. It would also help if anyone knew the dimensions of the crank and cam gears (i.e. Inner Diameter, width and outer diameter from tooth to tooth). Thanks.
Old Feb 11, 2007 | 05:21 PM
Whalesac's Avatar
Default Re: Timing Assembly...Crank Gear? (Whalesac)
Anybody?
Old Feb 22, 2007 | 08:48 PM
seabass10369's Avatar
let you in on a little secret http://www.hondaautomotiveparts.com
Old Feb 24, 2007 | 08:52 PM
Whalesac's Avatar
Default Re: Timing Assembly...Crank Gear? (seabass10369)
Well, that was looking promising for a moment...
http://www.hondaautomotivepart...ISTON
They have everything else that I would need to make this work, but they still don't have the crank gear. They have the crank gear pictured as #11, but on the parts/price list, they skip from 10 to 12...unless #12 is supposed to be the crank gear with a sepperate gear attatched to the back of it, which I highly doubt.
Thanks for the heads up though. I was also wondering what I would do for a tensioner, but the B-series is placed in about the same place the Quad4/Twin Cams have their's, so it looks like at least that might work.
Old Feb 24, 2007 | 09:59 PM
schardbody's Avatar
you are looking for part #17 i believe.
Old Feb 25, 2007 | 07:28 AM
Whalesac's Avatar
Default Re: (schardbody)
I didn't know the cr-v used a b-series motor. Regardless, I believe you are right as well, but if you look at the parts list for that, it skips from 16 to 18. I'm beginning to think that Honda doesn't have a replacement crank gear for you guys. Oh well. Thanks for the help though guys.
Old Feb 26, 2007 | 06:07 PM
schardbody's Avatar
my bad, part #12, same part, dont know why they show it illistrate it twice.
mountainrich
Classic Hondas
Jul 12, 2009 05:24 PM
EG-SIXV-TEC
May 11, 2009 03:00 PM
I8ayellowcrayon
Dec 27, 2004 07:51 PM
civickiller
Mar 8, 2004 11:34 AM
