vtec wiring help??
Old Feb 10, 2007 | 08:26 AM
GreddyCivic7's Avatar
Default vtec wiring help??
ok so im re-doing my eninge harness bc mine has been hacked by previous owner. car is 96 civic ex. and motor is 95 b18c i bought a 96 dx harness and boomsland 0bd2 to obd1 harness. can someone explain how to hard wire vtec to me? there is a seperate wire on the boomslang harness for vtec.
Old Feb 10, 2007 | 08:57 AM
Default Re: vtec wiring help?? (GreddyCivic7)
anyone? do i juss run from vtec solenoid thro firewall and into the ecu?? or for me into the vtec wire in the boomslang harness???
Old Feb 10, 2007 | 09:00 AM
Syndacate's Avatar
Is there any plugging into the VTEC pin on the ECU? It shouldn't matter, you should be able to do either if there's a wire plugged in there - I'd by-pass it though, go right to the ECU.
Old Feb 10, 2007 | 09:45 AM
wat im confused is the vtec solenoid is 2 wire. the vtec wire on boomsland harness to ecu is juss 1 wire. how i make that work???
Old Feb 10, 2007 | 03:35 PM
ttt
91 DA B18B1
Mar 25, 2011 08:15 AM
TeamRPM_ZC
Jul 14, 2008 08:36 AM
sammydigital
Jun 9, 2006 05:31 PM
allmotorteg_96
May 11, 2004 06:12 AM
9deuce9rr
Jan 7, 2004 03:17 PM
