Warm up Misfiring Problems
Old Feb 9, 2007 | 09:37 PM
ludeboi121's Avatar
Default Warm up Misfiring Problems
hey guys i dont usually post here, more on po.com but i have a situation i cant figure out. Let me list some specs before continuing;
99 5th gen base
JRSC @ 9lb
440CC RC injector
Greddy Emanage
NGK 1-step colder copper plugs
Currently at cold start the lude runs perfectly fine no problems at all, but once the lude warms up, i receive a blinking CEL 1399 which is random misfire. The car actually misfires as well through the axle-back. The weird thing is that the CEL will disappear but the car will continue misfiring. I have change my distributor rotor, cap, plugs and wires, still no luck. This problem actually occurred when i had my injectors reserviced at RC, the idle will drop as well while misfiring. while the car is at full throttle, this will hold up at 5k rpm. If anyone has any info or what steps to take next please let me know thanks
Old Feb 10, 2007 | 08:05 AM
ludeboi121's Avatar
Default Re: Warm up Misfiring Problems (ludeboi121)
bump please help
Old Feb 10, 2007 | 08:06 AM
Speedra500's Avatar
check your plugs to see how they look and see if you find anything
Old Feb 10, 2007 | 08:15 AM
ludeboi121's Avatar
Default Re: Warm up Misfiring Problems (Speedra500)
plugs looks like its running rich
Old Feb 10, 2007 | 02:26 PM
PrettyLude's Avatar
have you checked to see if you low on coolant?
Old Feb 10, 2007 | 02:56 PM
TDCTyler's Avatar
where do you gap your plugs at?
Old Feb 10, 2007 | 04:37 PM
ludeboi121's Avatar
Default Re: Warm up Misfiring Problems (spOolin97)
gap is done at stock .48 i think and then .35 for second set (force induction pregapped already)
coolant is alright checked as well from newly installed samco. done before and after still misfired.
Old Feb 10, 2007 | 11:00 PM
ludeboi121's Avatar
bump
Old Feb 11, 2007 | 01:51 PM
TDCTyler's Avatar
thats still too big, my car did the same thing as yours untill i went to a 0.25 gap.
Old Feb 11, 2007 | 04:00 PM
ludeboi121's Avatar
i ffound out it was the injectors, i got them switched out and no more misfiring. But now when i run the car at full throttle i can get past 1st gear but 2nd, 3rd, 4th etc the car cant rev past 5k rpm. feels like the car tries to push but it holds back, kinda like back pressure
Old Feb 11, 2007 | 04:22 PM
98vtec's Avatar
moderator emeritus
does greddy emanage have the ability to scale the injectors so not so much fuel is dumped at idle?
Old Feb 12, 2007 | 01:51 AM
BlownH23a
Guest
Posts: n/a
check your map sensor and map sensor vac lines, i ran rich for over a year before i discovered that one of the lines was compromised...just inspect them closely..it was a headache!
moore_716
16
Feb 23, 2015 06:15 PM
zanglezonker
Dec 9, 2008 04:17 AM
JDM_SOHC
26
Jun 28, 2006 11:55 AM
kooter
Apr 6, 2006 10:45 AM
Touge Tuning
Jun 27, 2005 06:42 AM
