Coolant smell after vtec...
Old Feb 9, 2007 | 08:05 PM
UNforgivABLE's Avatar
Default Coolant smell after vtec...
Im scarred it could be the headgasket? Its definately coming from teh vents after i drive aggresively. Definately coolant.
I have no overheating issues
I have no oil in radiator or overflow
I do have what appears to be coolant stains/drips on parts of my block but i cant trace the source.
I have high comp pistons..could it be headlift? Can i definately rule out the head gasket or no?
Car made good power on teh dyno and runs strong.
Old Feb 9, 2007 | 08:10 PM
LunchboxZT's Avatar
Default Re: Coolant smell after vtec... (Teh Wolfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teh Wolfe &raquo;</TD></TR><TR><TD CLASS="quote">I do have what appears to be coolant stains/drips on parts of my block but i cant trace the source.</TD></TR></TABLE>
I'd start there..
Old Feb 9, 2007 | 08:16 PM
rjgerolaga's Avatar
check the heater hose and coolant line on your intake manifold.
Old Feb 9, 2007 | 08:47 PM
OG undercover's Avatar
clean it all very thoroughly and then start looking. It should be easy to find that way.
If it's what I think. get a pressure tester for the coolant system. it will force the leak to show it's self quickly.
Old Feb 9, 2007 | 08:50 PM
hayabusa160's Avatar
Default Re: Coolant smell after vtec... (Mike Hancho)
i got the same prob. i got a leak from one of the coolent hoses haha.
Old Feb 10, 2007 | 08:36 AM
BoBo Racing's Avatar
Default Re: Coolant smell after vtec... (hayabusa160)
do a test by running pressurised system in the colant lines
Old Feb 10, 2007 | 01:06 PM
Ed 341's Avatar
Check the seam around the top of the radiator. This sometimes leak, which would explain the coolant on the engine.
Old Mar 10, 2007 | 05:18 AM
b18c4door's Avatar
Default Re: Coolant smell after vtec... (Ed 341)
what was the problem. I have the same exact issue on my bone stock GSR!
Old Mar 10, 2007 | 08:14 AM
MatrixShark's Avatar
It's silly but, I once didn't put the hose clamp back on one of the lines on the bottom of my TB. Once the car got real hot it would leak a little out of that hose. I agree with the guy that says to clean it and than test under pressure.
Old Mar 10, 2007 | 03:00 PM
itr1244's Avatar
Default Re: (MatrixShark)
i think i found few drops of coolant on the floor of my garage.. and it was right underneath the thermostat housing..
but i haven't had chance to fix that problem yet.
i can't smell coolant when i drive it hard.. i sometimes smell the coolant when i give sudden throttle at lower rpm
Old Mar 10, 2007 | 04:26 PM
b18c4door's Avatar
Default Re: (itr1244)
I will check tomorrow and post up...Thanks for the replies!
SeanK325
Jun 22, 2010 02:52 PM
vroomboom
Honda Civic (2001 - 2005)
May 22, 2008 04:44 AM
tigueremalo
Jul 10, 2006 07:16 PM
george34
May 7, 2006 07:09 AM
ckur1y
Feb 15, 2006 06:41 PM
