Rear wheel spacers?
Old Feb 9, 2007 | 05:45 PM
EJ8 GSR-T's Avatar
Default Rear wheel spacers?
Does anyone have wheel spacers on the rear of their ej coupe? I am wondering how it could look with some nice wheels and a bit of camber?
Old Feb 10, 2007 | 09:37 AM
EJ8 GSR-T's Avatar
Default Re: Rear wheel spacers? (EJ8 GSR-T)
Old Feb 10, 2007 | 09:42 AM
Sean @ ESG's Avatar
It depends on what offset your wheel's are, and how big of a spacer you run.
Old Feb 10, 2007 | 10:13 AM
EJ8 GSR-T's Avatar
Default Re: (Sean @ ESG)
Have any pics for ideas? Im just lookin to give my car a bit more intersting stance.
Old Feb 11, 2007 | 09:38 PM
iam7head's Avatar
Default Re: (EJ8 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">Have any pics for ideas? Im just lookin to give my car a bit more intersting stance.</TD></TR></TABLE>
adding more tracking in the rear will add more understeer, do you really want that on your fwd honda?
plus if you are lowered you might bump into rubbing issue
Old Feb 11, 2007 | 09:51 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (iam7head)
besides i haven't seen many spacers that werent smaller than a 15mm.. so w/ a +40 wheel, that would take you to a +25mm offset! which wouldn't work in the rear w/ out excesive amounts of camber and alot of fender rolling. my +35mm wheels rubbed in the rear. oh and youll need extended studs as well! and like said above, understeer would be horrible!
Old Feb 11, 2007 | 09:55 PM
Sean @ ESG's Avatar
Default Re: (spock_rocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">besides i haven't seen many spacers that werent smaller than a 15mm.. so w/ a +40 wheel, that would take you to a +25mm offset! which wouldn't work in the rear w/ out excesive amounts of camber and alot of fender rolling. my +35mm wheels rubbed in the rear. oh and youll need extended studs as well! and like said above, understeer would be horrible!</TD></TR></TABLE>
Project Kics makes a 10mm one with studs on it, and Ichiba makes a 5mm and 10mm ones.
Old Feb 11, 2007 | 10:00 PM
Regal's Avatar
Ladies and gentlemen we are floating in space...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have wheel spacers on the rear of their ej coupe? I am wondering how it could look with some nice wheels and a bit of camber?</TD></TR></TABLE>
You could also just look at pics of cars with low offset wheels since all the spacer does is lower the offset. Some car may have 5mm spacers, but if you're starting with a +42 wheel, there's not much to look at.
Old Feb 11, 2007 | 10:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean @ ESG &raquo;</TD></TR><TR><TD CLASS="quote">Project Kics makes a 10mm one with studs on it, and Ichiba makes a 5mm and 10mm ones.</TD></TR></TABLE>
touche'
DUSTY4DOOR
Honda S2000
Apr 7, 2012 11:07 AM
89hatcher
May 8, 2008 10:52 AM
90hbvtec
Apr 2, 2007 05:11 PM
Kanges
May 25, 2004 09:29 PM
jvcnyc
Apr 4, 2004 06:59 PM
