Is anyone runing cable to hydro converter .. If so plz put your input
Old Feb 9, 2007 | 04:04 PM
DraginTeg93's Avatar
Default Is anyone runing cable to hydro converter .. If so plz put your input
Is anyone runing this set up and if they are how is it .. does it work good . is it worth the money that it cost .. Thanks
Designed for B or D Series engines with a hydraulic transmission. The actuator will convert from cable to a hydraulic transmission. 100% bolt in, no modifications required. Actuator mounts in front of the release fork. There is no binding or premature clutch/transmission wear
Old Feb 9, 2007 | 04:57 PM
Extreez's Avatar
Default Re: Is anyone runing cable to hydro converter .. If so plz put your input (DraginTeg93)
thats kinda neat, id like to know too
Old Feb 9, 2007 | 07:50 PM
Default Re: Is anyone runing cable to hydro converter .. If so plz put your input (Extreez)
anyone ?
Old Feb 9, 2007 | 08:55 PM
iBrandon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DraginTeg93 &raquo;</TD></TR><TR><TD CLASS="quote">anyone ?</TD></TR></TABLE>
Doood its friday night...people are out....Be patient! most likely tomarrow you will get some responses....
Old Feb 10, 2007 | 08:12 PM
some input . would like to know before I buy it this week
Old Feb 11, 2007 | 01:12 PM
Extreez's Avatar
bump
Old Feb 11, 2007 | 01:39 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
just convert your clutch pedal assembly from cable to hydro. take all the clutch parts from a 94+ teg and swap it all over.
Old Feb 22, 2007 | 09:44 PM
Extreez's Avatar
Default Re: (full Circling)
whats the diffrence wit cable and hydro ?
Old Mar 20, 2007 | 11:58 AM
CRX931's Avatar
Default Re: (Extreez)
those things are ****! my buddy had one on his da and it made the clutch pedal stiff as hell it was like pressing the brake pedal. He has broken two clutch cables and the entire piece bent inward toward the transmission due to the stiffness so he can't even disengage his clutch completely, the problem is the linkage is too short , compare it the cable trannys you will notice that the cable tranny linkage arm is about 3 times longer resulting in less pedal effort
ricekiller1
Feb 2, 2008 07:46 PM
luvs2spooge
Aug 31, 2007 06:34 AM
ldanphanl
Mar 6, 2005 08:50 PM
honda-tech
Nov 14, 2004 02:12 PM
99AccordCF8
Mar 27, 2004 12:29 PM
