How to change my coolant on my EG
Old Feb 9, 2007 | 09:26 AM
frank358fr's Avatar
Default How to change my coolant on my EG?
I was wondering how to change my coolant on my EG because my car are low to heat...
Thanks
Frank
Old Feb 9, 2007 | 09:28 AM
MiamiEJ1's Avatar
Default Re: How to change my coolant on my EG? (frank358fr)
https://honda-tech.com/zerothread?id=1424191
all you had to do was search
Old Feb 9, 2007 | 09:46 AM
SkoundrelUSA's Avatar
cute little bastard
Summary:
1) With the car completely cooled off, lift front end of the car if you can't get under it as is
2) Open radiator cap. Look for the plastic looking screw at the bottom of radiator
3) Drain it into a pan or bucket
4) Tighten screw back up, lower car
5) Fill the radiator with coolant/water/whatever
6) Leave cap off, turn on the car with the heat on hot FULL BLAST
7) Allow the radiator to let air bubbles out, and keep filling the radiator back up as coolant level goes down.
8) Do this until level does not go down anymore, temperature gauge is at normal and the heat is actually hot
9) If it doesn't get hot, try giving it a couple small revs and wait
schumi
Jun 21, 2008 03:27 PM
I3ooS710
Mar 25, 2006 03:45 AM
ALLMOTORD16Z6
May 20, 2005 03:27 AM
Spoonvtec
Nov 23, 2003 02:16 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
