Is a B-Series swap worth the trouble?
Old May 18, 2002 | 09:45 PM
SC0TT's Avatar
Default Is a B-Series swap worth the trouble?
I am having second thoughts about dropping a B16 into my crx "dx " after reading all the problems people are having with their swaps. Theres so much that can go wrong; ordering a bad engine, wiring, idleing, messed up shifter, etc. <U>Is it all worth the work and trouble</U>?
[Modified by cr-tegra, 6:46 AM 5/19/2002]
[Modified by cr-tegra, 6:47 AM 5/19/2002]
Old May 18, 2002 | 09:49 PM
EP3_05's Avatar
Default Re: Is a B-Series swap worth the trouble? (cr-tegra)
I think it is worth it. I had a few problems in the beginning but once i fixed them the swap has been awesome. The car has a lot more grunt to it now and it was definitely worth it even though it did cause some headaches.
Old May 18, 2002 | 10:09 PM
Redline130's Avatar
Look at things optimistically. Trying to figure out why your car doesn't run right is a good way to learn about your car. It helps down the road when you need to trouble shoot any problems. A B-series swap is definitely worth the blood, sweat, and tears. Well at least IMO. Of course getting a bad engine to begin with totally defeats this way of thinking.
Old May 18, 2002 | 10:15 PM
Brandon Chun's Avatar
Default Re: Is a B-Series swap worth the trouble? (cyber13)
Let me be honest, if you're the kind of person that gets frustrated easily don't do it.
I've had a couple of times where I was just like you know what **** this I shouldn't have done it. Once, all the swap issues are resolved though I'd say it is definately worth it. It is definately a blast to drive
Old May 19, 2002 | 04:02 AM
Giuseppe's Avatar
Default Re: Is a B-Series swap worth the trouble? (Brandon Chun)
research research research is the key to a good swap
that is if youre doing it yourself.learn and ask as much as possible
and ask the RIGHT people.!!!
there are plenty of resources on the net...
if you got the $$$ take it to a reputable show and let them
'worry' about issues...
hth!
Old May 19, 2002 | 09:04 AM
flat-blk-HB's Avatar
Default Re: Is a B-Series swap worth the trouble? (Giuseppe)
I really believe it is well worth it. Just think about it you are putting a engine in the car that it didint come with. Of course there is going to be small problems. But that is something you can take as a learinging exp. I did my 1st b swap in my 89 DX and had to do everything. But I now feel more comfortable messing with the car you learn ALOT about your car.
As far as getting a bad engine just look around and dont buy the 1st one you find look and ask others to tell you about good reliable places to get the engine from.
_Brandon_
Old May 19, 2002 | 10:06 AM
SC0TT's Avatar
Default Re: Is a B-Series swap worth the trouble? (ED6)
Thanks for all the input everyone.
Old May 19, 2002 | 12:19 PM
puffinrice's Avatar
its totally worth it, but your never going to just take out the stock motor put in a different motor and think you aren't going to have problems. but i did it, and my god what a differance. so dude, its up to you but it is worth it
Old May 19, 2002 | 01:25 PM
Urban Business
Guest
Posts: n/a
Default Re: Is a B-Series swap worth the trouble? (puffinrice)
once you do the mpfi swap in that dx the actually motor swap will be cake. swaps arent hard to do.
Old May 19, 2002 | 01:34 PM
brad.'s Avatar
Default Re: Is a B-Series swap worth the trouble? (TorteX)
swap swap!!
Old May 19, 2002 | 02:30 PM
89 CRX SI's Avatar
in a honda that is dont go messing with crysler...... hehe
ShockZZie
Mar 31, 2017 10:23 AM
blue_EM1
31
Jun 22, 2008 01:06 AM
EGCivicChicago
Jan 19, 2007 03:43 PM
lukas
Dec 28, 2003 03:32 PM
** OF HAZARD
Jul 15, 2002 12:57 PM
