cleaning up an engine block???
does anybody have any suggestions on stuff to use to clean my engine up with? i can't use engine degreaser because it all says to run engine until warm. my engine isn't in the car, i wanted to clean it before it goes back in. I have tried simple green and some other stuff, not working too well?
I recently picked up a GSR block and it wasnt that dirty but i wanted to give it that "im a brand new block" look, so i used some penzoil degreaser and that stuff WORKS...a lot better than Gunk Brand degreaser..just my .02
if you have a disk sander, take that and get some of the scotch brite pads for it and use those, they work awesome. then after doing that, paint the block bl
ack and you won't have to worry about cleaning it again, and it looks awesome too. i did the same thing and i love it. but its up to you what color you paint it.
Use Castrol Super Clean...just spray it, let sit for a few minutes then hose it down. You may have to use a metal brush to scrun in between crannies. (Repeat as needed) Works better than simple green. I used this on 2 of my motors and it really works well. A gallon usually goes for less than $10 at your local Kragens or Auto parts store.
Gunk Engine Brite.........worked fine on mine, and i have the same problem. Also i used a sandblaster after taping off every frigging hole on that damn b18......engine looks better though, almost ready for paint
I used diesel fuel and a dremel tool.. it worked ok. probably not the best option though. It took a while, stunk, and the results weren't spotless..
http://www.fatboyraceworks.com/crx/i...g/DSCF0056.jpg
i been trying to clean up my ls block, i used steam cleaner, gunk all this stuff sucks. the hard part is gettin the grease and dirt out of the little nook and crannies.
