Climate Control Fan Settings. 1 doesn't work, 2,3,4 do correctly. Hypothesis?
From: Close to West Chester, PA, United States of America
Just wondering what it could be? Metal contact for the 1 position corroded? It's an all original 89 dx CRX. Best way to remedy? Is it serviceable?
Random question also. cooling fan (Radiator fan) runs constant since I bought the car. What normally fails? Fan relay, coolant temp sensor, or thermo-fan switch (read something about that in the Haynes). There is a CRX at the pick and pull I could go buy the relay from.
p3
p3
Search...this one was ask3ed a while ago; its a good quesion some guy gave a good explanation on how to fix it...if i find it i will send you the link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mintef »</TD></TR><TR><TD CLASS="quote">either the blower control switch is no good or the blower motor resistor.more than likely its the resistor</TD></TR></TABLE>
Your resistor is shot. You can find it attached to the blower motor housing. Take your glovebox off, to the right you will see the blower housing and a plate that is screwed into it. The plate has two screws holding it in and a 4 wire harness coming out of it. Unclip the wiring harness, undo the screws, and it'll pop right out. Replace with a new one.
Information on the resistor - Blower Motor Only Works On Setting 3 & 4?
Yay, something to do at the pick and pull!
Thank you guys very much. This search function is hit or miss. I've typed stuff in from threads I've JUST READ and they don't come up!
Also, who do we talk to to get this place organized a little bit? Engine/Trans, Electronics, Brakes/Suspension, etc... Would help... mr2oc.com has a good setup.
p3
(89crx and 87mr2 ftw!)
p3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoenix_iii »</TD></TR><TR><TD CLASS="quote">Yay, something to do at the pick and pull!
(89crx and 87mr2 ftw!)</TD></TR></TABLE>
I'd HIGHLY recommend not doing that, and getting a brand, spankin' new one at the dealership. It's only about 30 bucks, if prices haven't jumped too much. Otherwise, you'll just be doing this again soon, and waste your money.
Who needs "setting 1" anyway? Just use 2 if you're needing air moved. It's not like we have comfort cruisers anyhow.
DEPintheCurve
Jan 16, 2013 07:56 AM
