whats the difference between saturated and peak and hold injectors?
Old Feb 7, 2007 | 09:22 PM
chicken head's Avatar
Default whats the difference between saturated and peak and hold injectors?
Old Feb 7, 2007 | 10:09 PM
CE1's Avatar
CE1
Default Re: whats the difference between saturated and peak and hold injectors? (vtaaakkkk!!!)
for civics 92and up sat.
91 and down peak and hold[need a resitor box to work correctly]
Old Feb 10, 2007 | 10:32 PM
95dcsleeper's Avatar
Default Re: whats the difference between saturated and peak and hold injectors? (nonvtecek9)
how about when u run aem system? and why do u need the resistor box?
Old Feb 10, 2007 | 10:59 PM
JDM_dreamer's Avatar
i Think the only thing that effects this is what ecu and OBD a system is designed to work for.
the AEM system should come with instructions ad to what style injectors it wants you to use.
for OEM setups, you need to go with the ECU and/or OBD system you are running.
the engine itself doesn't know or care what injectors your using.
pardon the spaced, one idea per sentence typing, im drunk ( red headed ***** is an awesome drink BTW)
Old Feb 10, 2007 | 11:22 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: whats the difference between saturated and peak and hold injectors? (JDM_dreamer)
redheaded ***** are awesome chicks too
Old Feb 11, 2007 | 01:10 AM
Surfjunkie44's Avatar
Default Red Headed *****...
Ditto and x2 on that one!
Old Feb 14, 2007 | 08:30 AM
aquarius's Avatar
Default Re: Red Headed *****... (Surfjunkie44)
so, I have a 99 si and I have a p06 ecu that im using for the boost setup. Should I go for P&H or Saturated. its obviously an obd2 car, but it has a p06....so should I go for p&h plus a resistor box or am I still good to just get some sats? thanks.
Seems like i should just stick to sats because a p06 is from 92+. what do y'all thing.
Old Feb 14, 2007 | 08:38 AM
ham's Avatar
ham
peak and hold are low impedence injectors which require 7-12 ohms to operate.
saturated injectors are high impedence injectors which require no resistor box.
the difference is the actual injectors themselves. saturated injectors work better with the ECU and thats why honda started using them in '92. Although you cant get large injectors over 750cc that are saturated, that is usually enough.
Old Feb 14, 2007 | 08:42 AM
ham's Avatar
ham
Default Re: Red Headed *****... (aquarius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aquarius &raquo;</TD></TR><TR><TD CLASS="quote">so, I have a 99 si and I have a p06 ecu that im using for the boost setup. Should I go for P&H or Saturated. its obviously an obd2 car, but it has a p06....so should I go for p&h plus a resistor box or am I still good to just get some sats? thanks.
Seems like i should just stick to sats because a p06 is from 92+. what do y'all thing. </TD></TR></TABLE>
a p06 is a non vtec ecu... was it converted? i would go with RC 750cc saturated because you wont need to wire up a resistor box and its more than you will need. I had to get 1000cc injectors so I had to go through the pain of wiring up 10ohm resistors.
Old Feb 14, 2007 | 03:12 PM
aquarius's Avatar
Default Re: Red Headed *****... (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">
a p06 is a non vtec ecu... was it converted? i would go with RC 750cc saturated because you wont need to wire up a resistor box and its more than you will need. I had to get 1000cc injectors so I had to go through the pain of wiring up 10ohm resistors. </TD></TR></TABLE>
yes the p06 is converted. im running low boost, so i think 550 is the most ill need. (stock internals and 7-10 lbs of boost. )
Old Feb 14, 2007 | 03:51 PM
ham's Avatar
ham
yes the p06 is converted. im running low boost, so i think 550 is the most ill need. (stock internals and 7-10 lbs of boost. )</TD></TR></TABLE>
why get 550s? why not be safe and get bigger injectors? 550s are only safe to 285 hp @ 80% duty with 45psi fuel.
Old Feb 14, 2007 | 05:51 PM
aquarius's Avatar
why get 550s? why not be safe and get bigger injectors? 550s are only safe to 285 hp @ 80% duty with 45psi fuel.</TD></TR></TABLE>
you've got a point. but...do you think my car will make 285 hp on 10 lbs with a totally stock b16a2?
Lets say i did get 750s...would they be efficient at less than 285hp?
Old Feb 14, 2007 | 07:22 PM
ham's Avatar
ham
people think that if they get injectors that are bigger than what they need, their cars are going to run bad. its not the case! when people get HUGE injectors, they have problems at low rpm because the duty cycle is so low. you will be fine!
EKHWhat
Feb 2, 2007 05:38 PM
nikolai.
Mar 8, 2006 11:57 AM
aaronhume
Oct 25, 2005 11:52 PM
Chris99SI
Jun 1, 2005 01:58 PM
Gfunk176
Jul 18, 2002 05:09 AM
