Oh Crap! My vitara's wont are too small for my z6 :(
Old Feb 7, 2007 | 01:55 PM
funkified's Avatar
Default Oh Crap! My vitara's wont are too small for my z6 :(
this morning i had dropped off some parts to go into my build, which included a set of standard size vitara's and some eagle rods.
i just got a call from my builder and hes telling me that the clearance to the cylinder wall is too small! its something like 0.003 off from what it should be, if i installed these then i would be getting a rattle in the engine.
has this happened to anyone before? anyone wanna trade me for a set of oversized vitara's???
what are the benefits of going with an oversized pistons anyways?
Modified by funkified at 4:18 PM 2/7/2007
Old Feb 7, 2007 | 01:58 PM
chinkest_raver's Avatar
Hmm better bore out the block.
Old Feb 7, 2007 | 03:17 PM
DelSolDon's Avatar
Default Re: Oh Crap! My vitara's wont are too small for my z6 :( (funkified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funkified &raquo;</TD></TR><TR><TD CLASS="quote">
so that you can get the correct piston to wall clearance. the reason that your standard sized vitaras don't fit right is because you are probably trying to put them in a worn out 100k+ mile block. the cylinder bore has been worn out past the original 75mm (probably something like 75.25mm) just from years of use.
with oversized pistons, you bore to just slightly bigger than the pistons you are going to run.
Old Feb 7, 2007 | 03:57 PM
pdiggitydogg's Avatar
my cylinders are .004 over stock...but thats for forged pistons
90crxdriver
Jul 1, 2009 11:49 AM
SP GARAGE
15
Nov 7, 2007 03:09 PM
Tippyman
Apr 18, 2007 07:25 AM
dizzyroc88
Mar 15, 2005 05:57 PM
AgentJam
Apr 26, 2004 05:48 AM
