99-00 front end conversion
Old Feb 6, 2007 | 08:33 PM
Mdg5858's Avatar
Default 99-00 front end conversion
Hey i am looking to do the 99-00 front end conversion on my 97 coupe.. I know i need the bumper, fenders, hood, lights do i need the radiater support? Thanks
Also i am looking to buy the parts if you have any lmk thanks
Old Feb 6, 2007 | 08:53 PM
just Touge's Avatar
dont bother, its played.
Old Feb 6, 2007 | 08:54 PM
tn's Avatar
tn
Default Re: 99-00 front end conversion (Mdg5858)
you won't NEED a radiator support, but you will want to get one if you're one of those people that needs everything to be just perfect. the 96-98 radiator support will hold up just fine with a little modification.
Old Feb 6, 2007 | 08:55 PM
EP3Moschini's Avatar
Default Re: 99-00 front end conversion (tn)
yeah the rad support will be fine
Old Feb 6, 2007 | 08:58 PM
ATEJ8FTW's Avatar
you also need a grill.
Old Feb 6, 2007 | 08:59 PM
turbociviccoupe's Avatar
Default Re: (ATEJ8FTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATEJ8FTW &raquo;</TD></TR><TR><TD CLASS="quote">you also need a grill. </TD></TR></TABLE>
cause paul wall said show me them grillz.
Modified by turbociviccoupe at 10:24 PM 2/6/2007
Old Feb 6, 2007 | 09:03 PM
tha_badguy's Avatar
Default Re: (TougesSaloon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TougesSaloon &raquo;</TD></TR><TR><TD CLASS="quote">dont bother, its played.</TD></TR></TABLE>
theres a reason for that
stock vs. stock is looks alot better
Old Feb 6, 2007 | 09:09 PM
Mdg5858's Avatar
alright thanks i appreciate all the responses
Old Feb 17, 2007 | 08:22 PM
pr0j3ctej8's Avatar
no not really only if u want it like to fit really good like stock but dont needa worry it will fit just fine
Old Mar 2, 2007 | 01:12 AM
Ax3l's Avatar
What modification needs to be done to the rad support if you keep the 96-08 one?
Old Mar 2, 2007 | 07:51 PM
ATEJ8FTW's Avatar
if you want to put the 99-00 on the 96-98 you need to cut like two small pieces on each sides for it to fit.
Old Mar 2, 2007 | 07:55 PM
gezzuzz's Avatar
Default Re: (just Touge)
its about as played out as breathing.. but we still do it.. looks 100x better and comes out clean as hell.. no one notices if you do that conversion but they will notice if you don't have the conversion.. a must have for 96-98 owner
Old Mar 2, 2007 | 09:55 PM
ATEJ8FTW's Avatar
i can usually tell if they do the conversion because the rear bumper is still different.
Old Mar 2, 2007 | 10:09 PM
anavrin351's Avatar
i just looked at 97 then 2000 and couldnt tell a difference at all looked like hoods had same lines same lights and bumper what changes?
Old Mar 2, 2007 | 10:52 PM
ATEJ8FTW's Avatar
the grill is wider and the hood and lights are different sizes. the bumper has a special place/holder for the fog lights.
Old Mar 4, 2007 | 08:06 AM
96 EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anavrin351 &raquo;</TD></TR><TR><TD CLASS="quote">i just looked at 97 then 2000 and couldnt tell a difference at all looked like hoods had same lines same lights and bumper what changes?
they're the same shape yes, but the front bumper is different like ATEJ8FTW said they have the spot for the fog lights, also the headlights are different, the fenders are different, and the hood is a little longer. the grille is also different so they all need to be replaced. the tail lights have red/clear going on for the 99/00 while the 96-98 have amber white and red, oh and a difrerent rear bumper is used on the 99/00 which has better lines. I think i covered it about all....
95JDM
Oct 22, 2006 09:55 PM
DCsports06
Jan 4, 2006 12:34 AM
95ejjj
39
Oct 4, 2005 06:26 PM
hybrid98
Jun 26, 2004 10:17 AM
b20vtecEK
Jan 24, 2004 11:37 AM
