Brake Problem
Old Feb 6, 2007 | 12:08 PM
bibong's Avatar
Default Brake Problem
What does it mean if you are accerelating at 80 MPH and when u step on the brake, you steering wheel starts to shake really hard? This only happens when i pas the 60MPH. Is this something i need to get it fix soon, or i can drive it around for another 4-5 years.
Old Feb 6, 2007 | 12:12 PM
sol2hatch's Avatar
Default Re: Brake Problem (bibong)
4-5 years? lol. Well, I am sure your car is fine, but you might need new brakes, could be warped rotors, or could be a bad wheel bearing. When is the last time your car had its brakes done, and did the rotors get turned/replaced? And you should probably atleast look into the problem. You should be fine to drive around in the mean time.
Old Feb 6, 2007 | 12:23 PM
EL Vap133's Avatar
Means your rotors are warped, replace them and the pads and you'll be set.
Old Feb 6, 2007 | 12:26 PM
bibong's Avatar
Default Re: Brake Problem (EL Vap133)
warped rotars, that sounds like a serious problem huh? Can you give me an estimate quote on how much it will cost to get it fix?
Old Feb 6, 2007 | 12:33 PM
mr abstract's Avatar
yea, for sure warped rotors. when that happened to me..it wasnt too bad so i just had them resurfaced. i cant exactly remember the price but ~$50 (?) seems to stand out.
Old Feb 6, 2007 | 12:37 PM
Mario_D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bibong &raquo;</TD></TR><TR><TD CLASS="quote">What does it mean if you are accerelating at 80 MPH and when u step on the brake, you steering wheel starts to shake really hard? This only happens when i pas the 60MPH. Is this something i need to get it fix soon, or i can drive it around for another 4-5 years.</TD></TR></TABLE>
To get an idea of how much your rotors and pad will cost, go to http://www.autozone.com and do a search for your parts.
Rotors and pads are a very straightfoward task that does not require a lot of mechanical knowledge.
Good luck.
m-
Old Feb 6, 2007 | 12:41 PM
bibong's Avatar
Default Re: Brake Problem (Mario_D)
How do i know which wheels to be replaced. Do i jut go ahead and replaced all four?
Old Feb 6, 2007 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bibong &raquo;</TD></TR><TR><TD CLASS="quote">How do i know which wheels to be replaced. Do i jut go ahead and replaced all four?</TD></TR></TABLE>
rotors bro, not wheels
on mine..it was the fronts that were warped..but i guess you could do all 4 to be on the safe side.
Old Feb 6, 2007 | 12:59 PM
bibong's Avatar
Default Re: Brake Problem (mr abstract)
What' so great about the Baer Rotors? Should i just go with the basic ones?
Old Feb 6, 2007 | 01:01 PM
bmoua's Avatar
once you get your rotors resurfaced/buy new rotors and new pads then make sure to get your tires balanced just to be on the safe side.
markave
13
Oct 21, 2010 06:21 AM
almostvtec
Sep 5, 2010 07:29 PM
WalkerGSR1
Suspension & Brakes
Aug 13, 2006 02:36 PM
egg_baLLa
Feb 1, 2005 07:23 AM
95integrags-r
Jul 23, 2003 04:21 PM
