OT-Wheel Spacers
Old Feb 6, 2007 | 09:00 AM
Lucky-R's Avatar
Default OT-Wheel Spacers
guys, what the thickest spacers some of you have used without changing out the studs? im playing with the offset of some wheels i got for the R and using extended studs is something id like to avoid, but id like to maintain safety too. i havent had a chance to buy some spoon calipers yet, id love to, but i also know i'll be faced with this again in order for me to keep using my jdm 16 itr wheels. i know i'll need a 7mm spacer to comfortably fit the spoon caliper. atleast 8 full turns per lugnut right?
Old Feb 6, 2007 | 09:03 AM
BlueR's Avatar
Default Re: OT-Wheel Spacers (Lucky-R)
i would not go beyond 5mm on stock studs
Old Feb 6, 2007 | 09:05 AM
BlueR's Avatar
Default Re: OT-Wheel Spacers (BlueR)
in your case, if you go beyond 7-8mm, i would order up a set of studs from the Acura TL
Old Feb 6, 2007 | 09:06 AM
cltitus's Avatar
arp extended wheel studs never go wrong either
Old Feb 6, 2007 | 09:08 AM
BlueR's Avatar
Default Re: (cltitus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">arp extended wheel studs never go wrong either</TD></TR></TABLE>
this is a better option:
https://honda-tech.com/zerothread?id=244036
Old Feb 6, 2007 | 09:39 AM
walker111's Avatar
Default Re: (BlueR)
I ran into the same problem, I got the JDM 16's with spoon clappers. I tried out an 8mm spacer but was not comfortable with the amount of stud the lug-nuts grabbed. The 5's work without the need for new studs. Here is my thread....
https://honda-tech.com/zerothread?id=1847433
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=244036</TD></TR></TABLE>
Next time I do bearings, I will get the TL 3.2 series rear studs
Old Feb 6, 2007 | 09:46 AM
cltitus's Avatar
Default Re: (BlueR)
wow nice article. looks like i wont have to drill my spoon rotors. thanks
who wants a set of arp wheel studs ?
Old Feb 6, 2007 | 12:30 PM
JDM_EH2's Avatar
Not to thread jack...but what does everyone think about buying a set of QUALITY 15mm spacers and machinging them down to whatever size you want?? I don't see why it wouldn't work. Obviously you need longer studs...but this way you could get a set of hubcentric spacers and have them machined to whatever size you want. This is for sizes greater than 5mm obviously since H&R already makes a 5mm one. Just a though.
Old Feb 6, 2007 | 12:34 PM
walker111's Avatar
Default Re: (JDM_EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Not to thread jack...but what does everyone think about buying a set of QUALITY 15mm spacers and machinging them down to whatever size you want?? I don't see why it wouldn't work. Obviously you need longer studs...but this way you could get a set of hubcentric spacers and have them machined to whatever size you want. This is for sizes greater than 5mm obviously since H&R already makes a 5mm one. Just a though.</TD></TR></TABLE>
What about just buying a 10mm and machinging it down??
Old Feb 6, 2007 | 01:04 PM
JDM_EH2's Avatar
Default Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">What about just buying a 10mm and machinging it down?? </TD></TR></TABLE>
Haha well that would be the obvious answer...but I couldn't find any good 10mm spacers. Both H&R and Ichiba jump from 5mm to 15mm...
Modified by JDM_EH2 at 10:52 PM 2/6/2007
Old Feb 7, 2007 | 09:01 AM
JDM_EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">I ran into the same problem, I got the JDM 16's with spoon clappers. I tried out an 8mm spacer but was not comfortable with the amount of stud the lug-nuts grabbed. The 5's work without the need for new studs. Here is my thread....
Next time I do bearings, I will get the TL 3.2 series rear studs </TD></TR></TABLE>
Hey man have you ran into any problems running only a 5mm spacer?? I saw your thread awhile back and was just wondering how it's holding up!
Old Feb 7, 2007 | 09:02 AM
walker111's Avatar
Hey man have you ran into any problems running only a 5mm spacer?? I saw your thread awhile back and was just wondering how it's holding up! </TD></TR></TABLE>
I have NOT ran into any problems so far. Thats with spirited driving.
Old Feb 7, 2007 | 10:17 AM
JDM_EH2's Avatar
Awesome I think i may just go with 5mm spacers then.
Old Feb 7, 2007 | 10:20 AM
EG6-DC2's Avatar
I have had enough of this rubbing in of the 16's. I want them back!
Old Feb 7, 2007 | 10:27 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Awesome I think i may just go with 5mm spacers then.</TD></TR></TABLE>
Refer to the pictures in my thread. I'll try to get some new ones up, but some people are not comfortable with that spacing. On track I will be going back to the stock 15's, not necessarily because of the clearance though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
I have had enough of this rubbing in of the 16's. I want them back! </TD></TR></TABLE>
nevar!!
Old Feb 7, 2007 | 10:29 AM
EG6-DC2's Avatar
nevar!!</TD></TR></TABLE>
Then I am going to steal Mudds and leave him with a set of my 15's.
Old Feb 7, 2007 | 10:31 AM
walker111's Avatar
Default Re: (EG6-DC2)
Then I am going to steal Mudds and leave him with a set of my 15's. </TD></TR></TABLE>
I think Mudds car would look pretty retarded with some usdm 15's
Old Feb 7, 2007 | 10:34 AM
EG6-DC2's Avatar
I think Mudds car would look pretty retarded with some usdm 15's</TD></TR></TABLE>
Not my problem!
Old Feb 7, 2007 | 10:45 AM
JDM_EH2's Avatar
Well I have a set of 16" Rega's +45...but I don't want to run them daily.
allmotorek8
Suspension & Brakes
26
Jun 11, 2009 06:29 AM
MDM
15
Sep 5, 2007 09:39 PM
MR_FIX_IT
Sep 16, 2006 10:11 PM
JDM_SOHC
May 7, 2006 07:47 PM
GokuSSJ4
Sep 16, 2003 11:09 PM
