Humming Sound from Crankshaft Pulley area
Old Feb 5, 2007 | 07:50 PM
SlowSOHC-T's Avatar
Default Humming Sound from Crankshaft Pulley area
Well I did a Y8 swap in my motor that only had 60k miles on it and every once in a while I'll get a loud humming sound down by the crank shaft pulley. I will admit that the alternator belt will squeal sometimes, and the timing belt seemed to be in good condition. I haven't replaced either one though... Basically the sound is only every once in a while. Its a bone stock Y8 and this noise seems to be getting louder. Seriously i was in my house and could here it outside...
Anyone have any ideals?
Old Feb 5, 2007 | 08:30 PM
justjoshin531's Avatar
Default Re: Humming Sound from Crankshaft Pulley area (IWANTAHB)
harmonic balancer....
Old Feb 5, 2007 | 09:31 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWANTAHB &raquo;</TD></TR><TR><TD CLASS="quote">Well I did a Y8 swap in my motor that only had 60k miles on it and every once in a while I'll get a loud humming sound down by the crank shaft pulley. I will admit that the alternator belt will squeal sometimes, and the timing belt seemed to be in good condition. I haven't replaced either one though... Basically the sound is only every once in a while. Its a bone stock Y8 and this noise seems to be getting louder. Seriously i was in my house and could here it outside...
Anyone have any ideals? </TD></TR></TABLE>
first of all i would get that alternator noise fixed and go from there
dose the car feel like it is bogging?
because if it is a humming sounds like it would be belt related have you checked the tension on the timing belt any damage
other then that you have two choices
1. drive it until it breaks
2. pull the engine apart and look for something worn out
Old Feb 5, 2007 | 09:57 PM
SlowSOHC-T's Avatar
Yeah I've checked the T-Belt and didn't see any wear or anything but I'm going to get a new one and install it anyways. Im also just going to ahead and put a new alternator belt on as well. As for the car bogging only in low rpms, anything above 2500 is decent...
But I planned on checking those belts but its 11deg outside and that's some cold **** ..... LOL
Old Feb 9, 2007 | 04:08 AM
SlowSOHC-T's Avatar
Fixed the alternator belt and squeek went away but I'm still getting that humming sound. Its not all the time though! I checked the timing belt and it looks to be in good shape but looks like it might be just a tad loose..
Could that cause it?
Old Feb 9, 2007 | 05:13 PM
SlowSOHC-T's Avatar
Anyone?
Old Feb 10, 2007 | 09:27 AM
SlowSOHC-T's Avatar
On1wheel
Dec 28, 2018 08:44 AM
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jun 6, 2010 08:39 PM
Samuels
Sep 30, 2009 06:16 AM
dcdcdc
Jan 30, 2008 02:49 PM
EFin' Kyle
Nov 10, 2004 10:00 AM
