Coolant Leak!
So I think I have narrowed down my problem to an external coolant leak on my 5th gen accord. My mechanic flushed/bled/refilled the coolant tank twice and said there were no air bubbles or leaks. However, after I park the car a substance leaks from the upper left part of the car near the tire. I checked the substance and its the same as what is in the coolant tank. Could this still be a bad thermostat issue or is a hose broken or what?
i would check your hoses. check the upper and lower radiator hoses for cracks. then i would check around the head gasket. check your thermostat and make sure your radiator isn't cracked.
after driving a good 20 miles it leaked about a 7 inch by 4inch puddle of the coolant. i forgot to mention that i just got the car back from the shop due to severe front end collision damage so the radiator was replaced but i dont know about the hoses, and they may have been torn i just dont know how i can tell
trust me you can tell if the hose is messed up. i was driving my 87 civic one day and the upper hose just popped, and you could see a 3 inch long rip. so ya just look at them and you'll be able to tell if there bad or not. there really easy to replace also
Teamdiesel
40
Dec 3, 2019 04:10 PM
