Questions about cat-back custom exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03EM2_EX »</TD></TR><TR><TD CLASS="quote">what size piping on em2 n/a should get?
Do they make a port for the o2 sensor to hook up?
do you need a resonator?
Also is t smog legal?</TD></TR></TABLE>
1. 2.5" piping.
2. Oxygen Sensor bungs can be welded onto existing piping.
3. No, you don't need a resonator, but you do need a Catalytic Converter to stay legal.
4. Turbo's? Don't know what you're asking.
1. 2.5" piping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">
1. 2.5" piping.
4. Turbo's? Don't know what you're asking.</TD></TR></TABLE>
Holy crap Matt, 2.5" are u kiddin? i would use than on maybe a k20a2, but NO WAY on a d17.
Im running 2.25", and I noticed a drop in low end. If i was to do it all over again, 2" FTW with a d17a1, a d17a2 MIGHT be able to get away with 2.25", but 2.5" is WAY to big.
Heres my answers to your questions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
Also is t smog legal? </TD></TR></TABLE>
1) 2.25"
2) THe 02 sensors usually go into the catalytic converter, and yes they can put a cat on ur custom exhaust
3) no u do not need a resinator
4) THe only legalities with exhaust are, #1 YOU MUST have a catalytic converter #2 You MUST pass smog regulations ( emissions testing) and in most places #3 you much be under a certain level of dB. <-- Loudness
1. 2.5" piping.
1) 2.25"
Stock is 1 5/8 or 1.75 IIRC. 2" is fine for NA. And your best bet is from the header back witha new cat as well. There downpipe is double walled and there's a donut in the back of the cat cutting the diameter down. So opening up the back end does very little without also opening up the front.
Building custom exhaust, 3inch and need to know where to get 3inch resonater and 3inch resonated tes
BolivianFuego
Oct 26, 2003 09:36 PM
