gas cap issue
Well my check engine light has been on for a while and the code is that classic one for the gas cap. Retightening and resetting the computer has not worked. Today when I filled up I noticed that I am missing the little metal flap that is closed when you are not refueling. Unless 1999 Honda Accord, 4 cyl., didn't come with one, perhaps mine has broken off? I would think that this would be causing the light to come on, as its not a tight seal. Any thoughts? Could I plug this up with some kind of rubber stopper?
I have a '99 Accord, and I don't have the flap you're referring to. It doesn't produce any kind of seal anyway. To be honest, I don't know if the car is supposed to have one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poly35 »</TD></TR><TR><TD CLASS="quote">Well my check engine light has been on for a while and the code is that classic one for the gas cap...</TD></TR></TABLE>
What shape is your gas cap in? If it looks like it's been dropped, consider buying a new gas cap from the dealer.
There's the gas cap holder on the fuel door but it's possible that the previous owner put in on the car and it dropped off, or whatever.
When you put gas in then put the cap back on, you are letting it click a minimum of three times, right? If you just put it on until the first click you aren't getting the seal that you need. Remember - three clicks (per the owner's manual).
FunkTechNician
Feb 1, 2011 02:31 PM
Accord-Guy
Mar 12, 2009 06:37 PM
mooneybeams
Aug 20, 2008 06:36 PM
willjamu
Mar 2, 2008 01:56 PM
