brake problems with 92 civic dx hatch
Old Feb 5, 2007 | 03:09 PM
92eg6b16's Avatar
Default brake problems with 92 civic dx hatch
ok i've replaced the master cylinder, booster, calipers, hoses, pads, and rotors on my hatch (stock brake system) and after the car has been driven for a few minutes the pedal gets stiffer and stiffer until there is no play and the calipers start closing and get tighter and tighter until i have to put foot almost all the way in it to keep the car moving..i've bled the brakes 8 times, no air, and am just not sure where to go
Old Feb 5, 2007 | 03:22 PM
ek_kid's Avatar
Default Re: brake problems with 92 civic dx hatch (92eg6b16)
mabe try adjusting the pedal did it do this be for the master cylinder? Have you checked the rear drums to see if the e brake cables are stuck?
Old Feb 5, 2007 | 03:24 PM
ek_kid's Avatar
Default Re: brake problems with 92 civic dx hatch (ek_kid)
if you jack it up is it just one wheel or all the wheels? it might be a brake hose because if they get pinched they can work as a one way check valve.
Old Feb 5, 2007 | 08:04 PM
Mista Bone's Avatar
D Tranny Guru
bad valve between the intake and booster
rockrig
Nov 21, 2011 02:01 AM
92eg6b16
13
Mar 10, 2007 04:30 PM
GdmLaz
Apr 5, 2006 07:49 PM
wicx
Nov 15, 2002 10:35 AM
veejay
Jul 24, 2001 09:39 AM
