heater doesnt work anymore...
Old Feb 5, 2007 | 01:01 PM
civicb16eg's Avatar
Default heater doesnt work anymore...
so i did a gsr swap into my cousins 99 civic ex...but after the swap the heater does not work anymore..anyone have any ideas to why?
NBPdEeCeE's Avatar
* B A N N E D *
Default Re: heater doesnt work anymore... (civicb16eg)
It's a pain in the *** but check the heater core?
Old Feb 5, 2007 | 01:02 PM
carboncivic's Avatar
Default Re: heater doesnt work anymore... (ViSioNxBoY)
Ya, check the heater core first
Old Feb 5, 2007 | 01:04 PM
99hondacura's Avatar
From: down the street,bythe river in the van, co, united states
where is the heater cor located at
Old Feb 5, 2007 | 01:08 PM
NBPdEeCeE's Avatar
* B A N N E D *
Default Re: (99hondacura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99hondacura &raquo;</TD></TR><TR><TD CLASS="quote">where is the heater cor located at</TD></TR></TABLE>
Take apart the dash and you'll see this white looking box - it should be just about where the center console would be. I've took apart my integra dash 4 times because I was leaking coolant into my driver side floormats but I took apart the heater core and found the tubing was BENT somehow, and I just bent it back into a circle. Voila ! Heater works and no more coolant leaks
...That had nothing to do with Civics sorry.
But yeah its a pain but thats the first place I'd check.
Old Feb 5, 2007 | 01:09 PM
kyle h.'s Avatar
Default Re: (ViSioNxBoY)
did you hook up the heater control valve properly?
Old Feb 5, 2007 | 04:59 PM
civicb16eg's Avatar
Default Re: (kyle h.)
what is the heater control valve?
Old Feb 5, 2007 | 10:41 PM
simplyrob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyle h. &raquo;</TD></TR><TR><TD CLASS="quote">did you hook up the heater control valve properly?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb16eg &raquo;</TD></TR><TR><TD CLASS="quote">what is the heater control valve?</TD></TR></TABLE>
i think that means no.
Old Feb 5, 2007 | 10:43 PM
snoopiie's Avatar
Default Re: (simplyrob)
He's gonna have some problems ...
Old Feb 5, 2007 | 10:47 PM
B18CivicEH2's Avatar
hum....if the heater was workin before, i dont think the heater core would be it.....maybe you didnt connect the lines or maybe the motor has might need a new thermostat..
Old Feb 6, 2007 | 03:25 AM
RATED EG's Avatar
Default Re: (B18CivicEg)
it can also be the thermostat. might be stuck open
Old Feb 6, 2007 | 03:35 AM
Syndacate's Avatar
Default Re: (RATED EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RATED EG &raquo;</TD></TR><TR><TD CLASS="quote">it can also be the thermostat. might be stuck open</TD></TR></TABLE>
Doubtful.
Even if his thermostat was stuck open his heater would work fine after the car reached standard operating temperature - just not well at all on the long *** warmup .
@OP: I'm assuming blower motor is okay? If you turn it on like, "1" on the defoggers or the feet and then you put your hand on the vent, do you feel heat? Or is it not blowing strong? Or is it blowing ice cold? Or is it only blowing ice cold during warm up?
Please give us more info...?
Old Feb 6, 2007 | 03:59 AM
RATED EG's Avatar
Default Re: (Syndacate)
i had a problem with my thermostat. it was stuck open. and it didnt get warm at all. checked everything. thermostat was the last thing i checked and after i fixed it. my heater blows nice and hot
Old Feb 6, 2007 | 06:26 AM
TX_RSX254's Avatar
im having the same problem... and its cold as **** outside!!
Adankid
Oct 17, 2008 01:41 PM
mrsalesco
May 23, 2007 10:01 PM
iwantspeed
Honda Civic (2001 - 2005)
12
Jan 26, 2007 01:29 PM
1988c-rex
Nov 11, 2005 04:09 AM
KanzenR95GSR
May 11, 2004 09:02 AM
