Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Common acceleration issue?
Old Feb 5, 2007 | 12:00 PM
Miracle's Avatar
Default Common acceleration issue?
Got to drive my buddy's '06 Si the other day, and I noticed an issue with what felt like a misfire/hesitation. The car has the Injen CAI, with a "filter condom" on the end of it, so I am fairly sure he hasn't sucked any water up.
It will have a SLIGHT hesitation right around 3,500-4,500 RPM in all gears. I have personally checked all the filter connections, hose clamps, vacuum lines and electrical connections, all to no avail.
The car isn't throwing any DTC's, so a computer scan is out of the question (because I have already put my OBD2 scanner on it, with no stored codes).
Any ideas?
EDIT: I know for sure it isn't the DBW throttle lag common to these cars, because he already has the Hondata Reflash, which has ALMOST eliminated the lag all together.
Old Feb 5, 2007 | 12:41 PM
blue rocket's Avatar
Default Re: Common acceleration issue? (Miracle)
While i can't tell you what it is that's causing the hestitation, i can tell you that my stock (except for K&N drop in) Si has absolutely no lag anywhere in the powerband. My thought is that it's because of the intake, did you unplug your battery for 1-15 mins then let the car idle for another 15 mins? If not, i'd suggest trying that...
Old Feb 5, 2007 | 12:44 PM
Miracle's Avatar
Default Re: Common acceleration issue? (blue rocket)
We did that... to let the ECU "relearn" the idle fuel mixture or whatever, as the instructions suggested, so that SHOULDN'T be the problem.
I am thinking something electrical, or there is an air/vacuum leak somewhere. When he get's off today, I will take a look again and see what I can come up with.
Old Feb 5, 2007 | 01:09 PM
Demonis's Avatar
Try putting the stock setup back on and see how it reacts.
Old Feb 5, 2007 | 01:16 PM
Miracle's Avatar
Default Re: (Demonis)
Well... we found that problem fairly quickly with a quick check...
When he installed the intake, he didn't screw the MAF sensor all the way in it's setting.... it is running right now, relearning the idle air mixture... and we will see how it goes from there.
Old Feb 6, 2007 | 03:08 AM
RICO_'s Avatar
NO MERCY!
Default Re: (Miracle)
Only slight hesitation I had was around 3100 rpm where the I-vtec begins to "kick".
integra_101
Jul 20, 2013 10:43 AM
92civicx
Oct 17, 2007 06:27 PM
EuroKing99
May 11, 2006 04:29 PM
JKpookma
Oct 20, 2004 02:08 PM
tommyd
Feb 26, 2003 08:14 PM
