starting crx in the cold
Old Feb 5, 2007 | 07:09 AM
1000_miles's Avatar
Default starting crx in the cold
it is cold and my crx won't start. I've thought about taking the battery out to thaw it then jump it. the bad part is the hood is frozen shut so I can't get to it. there is an electric cable I find underneath the hood. I've not get to use this before. Does anyone know, can I use this to plug into an electric outlet and start the car?
Old Feb 5, 2007 | 07:38 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: starting crx in the cold (1000_miles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1000_miles &raquo;</TD></TR><TR><TD CLASS="quote">it is cold and my crx won't start. I've thought about taking the battery out to thaw it then jump it. the bad part is the hood is frozen shut so I can't get to it. there is an electric cable I find underneath the hood. I've not get to use this before. Does anyone know, can I use this to plug into an electric outlet and start the car?</TD></TR></TABLE>
If it has a three prong plug, it's more than likely a block heater. See if it runs to a plug on the back of the block, if it does, plug it in and enjoy your toasty warm engine.
Old Feb 5, 2007 | 08:40 AM
1000_miles's Avatar
Default Re: starting crx in the cold (wiZCo)
thanks. are there any safety measures? what is the amount of time I do this for?
Old Feb 5, 2007 | 08:42 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1000_miles &raquo;</TD></TR><TR><TD CLASS="quote">thanks. are there any safety measures? what is the amount of time I do this for?</TD></TR></TABLE>
usually you leave it plugged in all night.
Old Feb 5, 2007 | 08:51 AM
unusual71's Avatar
ya it keeps the coolant warm so the block doesn't turn into a little icicle over night. just DONT forget to unplugg it before you drive away!!
Old Feb 5, 2007 | 08:57 AM
Tippyman's Avatar
Default Re: (unusual71)
If you had properly mixed coolant, shouldn't this not be a problem? I can see why a battery warmer would help, but why is a block heater needed with properly mixed coolant?
Old Feb 5, 2007 | 09:00 AM
88LXi68's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">If you had properly mixed coolant, shouldn't this not be a problem? I can see why a battery warmer would help, but why is a block heater needed with properly mixed coolant?</TD></TR></TABLE>
It is not just for coolant. It is for the oil as well. Oil gets THICK when it is cold, so by having a block heater it warms the oil as well so that it prevents or minimizes cold start damage.
Old Feb 5, 2007 | 09:02 AM
Tippyman's Avatar
Default Re: (88LXi68)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88LXi68 &raquo;</TD></TR><TR><TD CLASS="quote">
It is not just for coolant. It is for the oil as well. Oil gets THICK when it is cold, so by having a block heater it warms the oil as well so that it prevents or minimizes cold start damage.</TD></TR></TABLE>
Makes sense...
Old Feb 5, 2007 | 09:04 AM
crxnj's Avatar
its not just for coolant or oil,,but also for the simple fact that its damn cold as hell and the engine would never warm up...you shouldn't need it though unless its 10 F and under
Old Feb 5, 2007 | 09:05 AM
Tippyman's Avatar
They have Genuine Honda engine and battery heaters still for sale on the Honda website. Are they in stock anymore?
Old Feb 5, 2007 | 09:23 AM
1000_miles's Avatar
thanks for all the response guys
Old Feb 5, 2007 | 09:40 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">They have Genuine Honda engine and battery heaters still for sale on the Honda website. Are they in stock anymore?</TD></TR></TABLE>
If you're seeing them on Majestic's website then yes.
Old Feb 5, 2007 | 04:14 PM
aRedSoxFanANDaCRXowner's Avatar
Default Re: starting crx in the cold (mr.speaker)
ANIFREAZE FTW
Old Feb 5, 2007 | 04:59 PM
janz3n's Avatar
Default Re: starting crx in the cold (B16_Miiiiiiiiiike)
battery shouldnt freeze.. so you dont really thaw it by warming it up.. your battery doesnt have enough cold cranking amps. your probably need a new battery.
Old Feb 5, 2007 | 07:05 PM
higgunscrx's Avatar
block heater ftw especially when its -40 C up here in the north (north bay ontario canada), makes starting so much easier
bought my block heater 2 months ago at the local honda dealership for about $35. the guy was supprised that they still had them in stock somewhere he said most accessories are all gone for our cars.
oh and the block heater installs on the front of the block just below the exhaust manifold. the large bolt.
Old Feb 5, 2007 | 07:09 PM
higgunscrx's Avatar
got the installation instructions somewhere around the garage can look for them if anyone is interested
Old Feb 5, 2007 | 09:59 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (higgunscrx)
yeah -40F is pretty freakin cold.. even 50/50 antifreeze water mix will freeze at -40f, which is also -40c, for the physics nerds among us. i would have to say that if your car doesnt have a block heater, or you are not running 0w-30 oil, then dont even try to start it until it warms up. all kinds of bad things happen to bearings that dont have oil because the oil is too thick.. just ask my roomate.... https://honda-tech.com/zerothread?id=1537221
David Kruegz
Honda Civic (2001 - 2005)
Jul 20, 2017 05:33 PM
Yuyodrift91
Mar 22, 2011 01:01 PM
lashubattie
Jan 18, 2009 08:05 PM
akaEsCo01
Dec 18, 2003 09:24 PM
Joseph Davis
May 12, 2003 01:27 AM
