APEX VTEC controller question?
Old Feb 4, 2007 | 10:12 PM
jeezyskillz's Avatar
Default APEX VTEC controller question?
ok i have a single cam vtec but iam having a hard time finding a p28 ecu can i connect the apex vtec controller by itself without having to use the p28 ecu? i have a dx ecu on there right now..........
Old Feb 4, 2007 | 10:17 PM
BlueIntegraBoy's Avatar
Default Re: APEX VTEC controller question? (jeezyskillz)
No, you can't. The VAFC does not and can not replace the ECU for functioning. You need a P28.
Old Feb 4, 2007 | 10:19 PM
o ok hey i also heard you can convert a auto ecu into a manual is this right? see cuz i got a p28 but it's auto.........
Old Feb 4, 2007 | 11:34 PM
frog169's Avatar
i used a p72 with a vtec controller for my civic with a b16
Old Feb 4, 2007 | 11:48 PM
Default Re: (jeezyskillz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeezyskillz &raquo;</TD></TR><TR><TD CLASS="quote">o ok hey i also heard you can convert a auto ecu into a manual is this right? see cuz i got a p28 but it's auto.........</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=708770
Old Feb 5, 2007 | 01:32 AM
just-an-lx's Avatar
i think you will have to get the p28
Old Feb 5, 2007 | 06:06 AM
evilsolb16's Avatar
Default Re: (just-an-lx)
you can convert to auto to manual ecu you have to remove rp17 and rp18 then put in a jumper on rp18. the will take way the auto trans in the ecu.
Old Feb 5, 2007 | 06:21 AM
Syndacate's Avatar
Default Re: (evilsolb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=708770</TD></TR></TABLE>
@ OP: This link isn't an answer - but it has the answer in it - which I copied/pasted here for you as the following:
And he said...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">no need to chip it if you want to keep the stock program. honda designed and built with most hardware to be quickly interchangable between trannies.
take a look at the following jumpers in the lower right hand corners of the ECU,
RP17 and RP18 values:
Auto to Manual:
remove RP17 and RP18
replace RP18 with a jumper wire
Pretty much what evilsolb16 says, but that has pictures.
Hope that helps ya .
Old Feb 5, 2007 | 06:31 AM
Syndacate's Avatar
Default Re: (Syndacate)
That picture that the other guy said kinda sux, so I took the liberty of doing some searching for you and came up with this:
http://hondaswap.com/~pills/autotomanual.html
Not the best picture, but it puts it in perspective as to where on the ECU you'll be working on.
http://www.pgmfi.org/twiki/bin...anual
There's a better version for the pictures, gives you a close up of what you're working on.
Really check out that second link, the pictures there are great!!
Civic Racer X 7
May 30, 2016 03:04 PM
donaldmejr
Aug 13, 2007 07:29 PM
Serdar
Feb 14, 2006 10:52 AM
a1320honda
Feb 18, 2004 01:29 PM
