Fuel pump question.
Old Feb 4, 2007 | 08:23 PM
Rhythmsnewsn's Avatar
Default Fuel pump question.
ok last night the car started up no problems, fuel pump primes and whatever and all of a sudden this afternoon i go to start the car and the fuel pump wont prime and the car wont turn over. im stumped, i even checked all the fuses and such. what could have possibly went wrong over night that would prevent the fuel pump from priming? im wondering if my pump died altogether? also, i forgot to mention that its like 15 degrees outside! so could temperature be an issue? i have no ride to work now so i need this fixed asap!
Old Feb 4, 2007 | 08:56 PM
oodie's Avatar
Default Re: Fuel pump question. (Rhythmsnewsn)
check main relay
Old Feb 5, 2007 | 10:19 AM
Default Re: Fuel pump question. (oodie)
anyone else?
Old Feb 5, 2007 | 10:24 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhythmsnewsn &raquo;</TD></TR><TR><TD CLASS="quote">anyone else?</TD></TR></TABLE>
did you check the main relay like mentioned? tap it with something see if it starts.
Old Feb 5, 2007 | 10:27 AM
jdmazm's Avatar
Default Re: Fuel pump question. (mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
did you check the main relay like mentioned? tap it with something see if it starts.</TD></TR></TABLE>
your problem definitely sounds like a main relay, has one of the symptoms thats for sure.
Old Feb 5, 2007 | 11:58 AM
Default Re: Fuel pump question. (jdmazm)
ill check that, thanks!
Old Feb 6, 2007 | 01:26 PM
ok, so i checked the main relay, its clicking so im assuming its getting power, but still no priming of the fuel pump, re-checked all the fuses under the dash and under the hood and none of them are blown. im guessing the fuel pump is no good now. can anyone confirm this?
Old Feb 6, 2007 | 04:29 PM
Crx Jimmy's Avatar
check at the plug under the seat or cargo box(civic or crx) and see if the pump is getting power. if it is getting power then bang on the tank with a hammer when someone is cycling the key. if you can hear it come on when you bang it, the pump is toast, or there was water in your tank and your pump is frozen up solid
Old Feb 9, 2007 | 05:17 PM
Default Re: Fuel pump question. (Crx Jimmy)
well after taking down the tank and pump and checking it all out, it turns out that some rust from the tank fell off inside and got cought up in my pump wich in return seized it up so now ive got a new pump, tank and filter
just putting that out there in case someone is having similar problems.
igone916
Oct 7, 2007 10:21 PM
kaychi
Mar 28, 2007 03:56 PM
Mag00n
Oct 6, 2006 10:24 AM
italstallion
Jul 11, 2006 03:04 PM
latindc2
Jun 5, 2006 07:23 PM
