Quick question about sohc/mini me...
Old Feb 4, 2007 | 04:54 PM
h22turbofiend's Avatar
Default Quick question about sohc/mini me...
quick question. can i use a 92-95 engine harness for sohc vtec in my 89 hatch if i get the right ecu and jumper harness, dizzy, injectors, etc? thanks for the help guys.
Old Feb 4, 2007 | 04:59 PM
flashedDc5's Avatar
Default Re: Quick question about sohc/mini me... (h22turbofiend)
no u have to use your stock harness
Old Feb 4, 2007 | 05:01 PM
Default Re: Quick question about sohc/mini me... (flashedDc5)
yeah but it is a dpfi. this is why i havent screwed wit the car yet. i can put a carbueretor on my malibu and be done with it...lol...i just want to do it as cheap as possible and do it one time, not half a$$
Old Feb 4, 2007 | 05:26 PM
dr_latino999's Avatar
You have to convert your DPFI harness to MPFI, then add the OBD-1 conversion harness into the mix. Pretty much, check wires 4 times, then cut and add.
1991hb's Avatar
just use your stock harness...all you have to do is convert to MPFI
Old Feb 4, 2007 | 05:49 PM
thanks for the help, i found an mpfi write up. i just want it to be right, reliable, and not half ***, i am a ase certified mechanic i am not afraid to do the work i just want to know the cheapest and best way to do it. thanks guys.
Old Feb 6, 2007 | 07:41 PM
master honda tech's Avatar
get a B16 bra
Old Feb 6, 2007 | 07:59 PM
Default Re: Quick question about sohc/mini me... (master honda tech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by master honda tech &raquo;</TD></TR><TR><TD CLASS="quote">get a B16 bra</TD></TR></TABLE> Is that one boob out of a 32B?
dets93teg
11
Jan 19, 2012 04:10 PM
InTheLBC20
14
May 21, 2009 10:21 PM
arsonest42
Feb 6, 2007 11:15 AM
h22blazerz5
Jan 24, 2006 02:18 PM
DevinW
Sep 17, 2002 01:31 PM
