got oil cooler....now what? :(
Old May 17, 2002 | 09:27 PM
Mr. Vapor's Avatar
Default got oil cooler....now what? :(
well,
i got the oppurtunity to jump onto an oil cooler, it was used 5 days, and the engine it was on blew, so i got it free, yes brand new. with SS inlet and outlet lines. even has a mini 3" fan that i can mount to the front with a toggle switch to cool it down even more.
my question is, well basically im lost, where do i tap for the inlet and outlet? how do i get the oil to the cooler, and return it back to the original "cycle"
i know, its a stupid question, but i dont know?
Old May 17, 2002 | 09:33 PM
Quaalude's Avatar
Default Re: got oil cooler....now what? :( (NYb16)
i think u need a sandwich plate adapter that goes in between the block and oil filter...the adapter should have 2 ports for u to connect the oil cooler lines
Old May 17, 2002 | 10:43 PM
rjardy's Avatar
Default Re: got oil cooler....now what? :( (Quaalude)
thats the only way i know of doing it....wel maybe you can run it off your turbo oil feed line........but it might take a little longer to get the oil to the turbo on initial startup, but i dont know. i would go wioth the plate like quaalude said.hth
ROB
Old May 18, 2002 | 12:55 AM
Lamchop0000's Avatar
your going to need this if you dont already have right one. http://permacool.com/Catalog/Cat_page28.html
or this
http://permacool.com/Catalog/Cat_page29.html
but then your goin to need a remote filter mount also if you use the spin on adaptor
http://permacool.com/Catalog/Cat_page30.html
i would get the sandwitch because its more conveient
late
[Modified by lamchop0000, 9:58 AM 5/18/2002]
Old May 18, 2002 | 01:14 AM
sleepy's Avatar
Default Re: got oil cooler....now what? :( (lamchop0000)
http://www.racerpartswholesale.com
I just ordered one from this place. Pretty cheap at around 24.00. They are on the East coast somewhere. Should get to you quickly.
Old May 18, 2002 | 07:54 AM
SiRkid's Avatar
Default Re: got oil cooler....now what? :( (sleepy)
i beleive an ITR comes with one of those from the factory....
Dre90
Apr 20, 2010 04:11 PM
big-cat
Jun 15, 2007 03:53 AM
done
Aug 2, 2004 08:50 AM
VTECAcuraGSR
10
Jul 12, 2004 01:26 PM
RRRex
Sep 30, 2003 10:59 AM
