possible problem??
Old May 17, 2002 | 09:07 PM
97AccordLx's Avatar
Default possible problem??
hello all
well SOMETIMES when the engine is cold and it warms up the rpms moving up and down
for example they move 100 up and 100 down
when th engine warms up its ok but even if i drive it with the engine cold it still runs fine
so whats the problem if theres any
thanks
my car has 118,000miles
Old May 17, 2002 | 09:12 PM
91DA9's Avatar
Default Re: possible problem?? (97AccordLx)
It is probably something in your cold idle system, I wouldn't worry a about it too much. If it really bugs you you can check the operation of your IAC.
Old May 17, 2002 | 10:28 PM
97AccordLx's Avatar
Default Re: possible problem?? (94IntegraGSR-OVR)
what does IAC mean and how do i check its operation
how much is a new valve cause i dont have any tools to check it so my mechanic will have to do it .....
Old May 18, 2002 | 06:44 AM
91DA9's Avatar
If you don't have the tools yourself then I wouldn't bother with it. It is not harming the car in any way, but if it really bothers you then take it to your mechanic and tell him to check operation of your idle air control. If he doesn't know what that is then find a different mechanic.
Old May 18, 2002 | 12:34 PM
Perfectionist's Avatar
This idle hunting is sometimes due to a leaking fast idle valve (FIV). The FIV allows extra air into the intake during cold starts and should close as the engine warms up. If it leaks, the normal idle control that the ECU tries accomplish with the IACV is impossible. I don't know which model you have, but a quick check to rule in/out the FIV would be to pinch off the air tube feeding it.
Old Jun 9, 2002 | 05:44 AM
97AccordLx's Avatar
Default Re: possible problem?? (Perfectionist)
wat tube? i have an intake ..
thajks
vdawg559
Jun 11, 2008 04:31 AM
verbal_assasin
Mar 1, 2006 01:09 AM
19_lude_s_96
Jan 4, 2006 04:33 PM
rudeman85
Oct 29, 2004 12:29 PM
crashtest Sonny
13
Mar 4, 2003 03:49 PM
