someone with helms manual...help please! im stuck!
Old May 17, 2002 | 09:00 PM
uNF$@#!'s Avatar
Default someone with helms manual...help please! im stuck!
Help!!! I'm in a jam!
could someone tell me what torque settings i should use to retorque the bolts that hold the shock in place? (5 bolts)
im stuck in the garage right now andi just forgot i lent out my helms to another h-t member (he's not home!)
TIA
[Modified by 00-0187, 1:04 AM 5/18/2002]
Old May 17, 2002 | 09:11 PM
uNF$@#!'s Avatar
Default Re: someone with helms manual...help please! im stuck! (00-0187)
Old May 17, 2002 | 09:17 PM
Renegade's Avatar
this is what the book says
Front suspension:
shock absorber
shock absorber to body mounting nuts 47 ft-lbs
shock absorber damper rod upper nut 22 ft-lbs
rear suspension:
shock absorber
Damper rod nut 22 ft-lbs
shock-to-lower arm bolt 40 ft-lbs
shock upper mounting nuts 36 ft-lbs
Not sure if this is what you are looking for...
Old May 17, 2002 | 09:24 PM
uNF$@#!'s Avatar
Default Re: someone with helms manual...help please! im stuck! (98401R)
thank you!!!
1990IntegraLS
Aug 15, 2015 06:29 AM
steveharrmr23
Nov 13, 2008 03:27 PM
Civicse
16
Dec 20, 2005 06:45 PM
Just2Fast
Jan 4, 2003 07:45 PM
quikrpm'z
Aug 18, 2002 08:48 PM
