How did YOU get your belt tensioner bolt out?
Old Feb 3, 2007 | 02:59 PM
JokerTypeR's Avatar
Default How did YOU get your belt tensioner bolt out?
I know some other have stripped their bolts. I rounded off the head. What'd you do to get it out?
I could probably figure this out on my own if I wasn't so fed up with the damn timing. I wanna go back to my D15B2...SOHC...no VTEC...nice, simple design...
Old Feb 3, 2007 | 10:01 PM
JokerTypeR's Avatar
Lookin' for ideas
Old Feb 3, 2007 | 10:12 PM
Sumslapper's Avatar
Year 3030
Default Re: (JokerTypeR)
smaller socket and pound it on? At my work we use a "lock breaker" that is a socket that starts off small on one end and flares out bigger. you whack it on until it cant be whacked anymore and then just break the bolt loose/off.
Old Feb 3, 2007 | 10:52 PM
Import_spoon's Avatar
Default Re: How did YOU get your belt tensioner bolt out? (JokerTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I know some other have stripped their bolts. I rounded off the head. What'd you do to get it out?
I could probably figure this out on my own if I wasn't so fed up with the damn timing. I wanna go back to my D15B2...SOHC...no VTEC...nice, simple design...</TD></TR></TABLE>
This is what you need to use. Works great on my stripped dizzy bolt.
Old Feb 3, 2007 | 11:57 PM
sal's Avatar
sal
Default Re: How did YOU get your belt tensioner bolt out? (Import_spoon)
These sockets work like a charm with stripped bolts.
Lol dont ask about the pic, it was the first one I found with a descent view of what the sockets look like.
Old Feb 4, 2007 | 12:30 AM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_spoon &raquo;</TD></TR><TR><TD CLASS="quote">
Needle nose vise grips? Yeah right. The tensioner bolt is under 42ft-lbs of torque. Not to mention the odd angle and tight spacing. Your best option is mentioned just above this post.
You could take it a step further and drill a hole big enough through your fender well in line with the tensioner bolt. This will allow you to get the proper leverage on the tool to bust it loose.
Old Feb 4, 2007 | 12:37 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: How did YOU get your belt tensioner bolt out? (Haleiwa-Brando)
You can find those crazy looking sockets from SEARS or any store that carries Craftsman tools. Good luck!
Old Feb 6, 2007 | 04:14 PM
JokerTypeR's Avatar
I just may have to go get me a set...for now and future use...how much does a set of them run? Any clue?
Old Feb 6, 2007 | 04:34 PM
Dogginator's Avatar
Daisy... Daisy...
Always use six-point sockets. Twelve-point sockets round bolt heads more easily.
Old Feb 6, 2007 | 04:36 PM
JokerTypeR's Avatar
Default Re: How did YOU get your belt tensioner bolt out? (Dogginator)
I did. I over tightened it last time I put it in...
Old Feb 6, 2007 | 04:44 PM
7andaswitchblade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I just may have to go get me a set...for now and future use...how much does a set of them run? Any clue?</TD></TR></TABLE>
they're pretty pricey. IIRC, we're talking like $60 for a set of 6 or something like that?
Some of you may hate on this, butttt...
If i need a special tool that I'll probably only ever use once, I'll buy it from sears, keep all the packaging and reciept, use the tool, then clean it up real good, and as long as i didn't damage it at all, return it.
Good way to get the job done, if you're on a tight budget for tools.
also, maybe you could fill a socket with something like JB weld, put it over the bolt, then leave it sit overnight so it hardens up, then try breaking it loose? Although if its completely rounded, i doubt that would work
Old Feb 6, 2007 | 08:08 PM
sal's Avatar
sal
Default Re: (7andaswitchblade)
Even though the sockets are pricey, they are incredibly useful. It will resolve problems like this in no time, and they are definitly worth having around.
Old Feb 6, 2007 | 08:14 PM
wernhersey's Avatar
Default Re: How did YOU get your belt tensioner bolt out? (sal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sal &raquo;</TD></TR><TR><TD CLASS="quote">These sockets work like a charm with stripped bolts.
Lol dont ask about the pic, it was the first one I found with a descent view of what the sockets look like.</TD></TR></TABLE>
These do work great, but spend the money and get a better brand, Craftsman is my prefrences.
Old Feb 6, 2007 | 08:58 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">You could take it a step further and drill a hole big enough through your fender well in line with the tensioner bolt. This will allow you to get the proper leverage on the tool to bust it loose.</TD></TR></TABLE>
so is the bolt off now, and is the engine even in the car still?
Old Feb 7, 2007 | 06:51 AM
JokerTypeR's Avatar
Default Re: How did YOU get your belt tensioner bolt out? (CleanLikeJdm)
Engine's in the car. I won't personally get to mess with it til this upcoming weekend. I left it at home with dad to try to work on. I'm about an hour north of home at school... If he didn't get it, I'll probably go buy a few of those nifty tool things. Maybe I can by them in singles...
Old Feb 7, 2007 | 08:35 AM
Dogginator's Avatar
Daisy... Daisy...
If you can get clearance, you could try to use a chisel and hammer to start the bolt turning CCW. If you have a welder, you could always weld another nut onto the stripped bolt head.
Old Feb 7, 2007 | 08:39 AM
JDMorgan's Avatar
Default Re: How did YOU get your belt tensioner bolt out? (wernhersey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wernhersey &raquo;</TD></TR><TR><TD CLASS="quote">These do work great, but spend the money and get a better brand, Craftsman is my prefrences.</TD></TR></TABLE> i have a craftsman 14mm one welded to a socket so it clears to remove head bolts and and between frame and engine for tensioner bolt.
White91EF
Nov 1, 2022 07:26 PM
ke7joi
Classic Hondas
Jul 16, 2014 07:51 AM
Bignel00
Jun 1, 2007 05:27 PM
2civic3
May 22, 2006 06:13 PM
B1894civic
10
Nov 29, 2004 10:18 PM
