Need good epoxy or liquid metal
Old Feb 3, 2007 | 01:35 PM
prelittlelude's Avatar
Default Need good epoxy or liquid metal
I need a very strong epoxy that will stick to Chrome Steel 52100, and the aluminum that our honda engines are made of. I want to stay away from JB weld. This is hold an after market bearing into a race. The race is the AL of the engine and the outer part of the bearing is chrome steel. the bearing does press in will alittle interference but i need some extra security. Would also be nice if it would withstand moderate head and oil/gas
thanks in advance for all the help
Old Feb 3, 2007 | 03:19 PM
Flashmn's Avatar
Default Re: Need good epoxy or liquid metal (prelittlelude)
I'd probably use loctite bearing mount.
Old Feb 4, 2007 | 06:44 AM
2point2's Avatar
Default Re: Need good epoxy or liquid metal (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">I'd probably use loctite bearing mount.</TD></TR></TABLE>
that stuff is nuts.
Is this a top secret project? There's a few ways of holding a bearing in place. I might be way off on this.. but it's hard without a picture
here's an easy way to do it if there is minimal thrust load on the bearing.
edit: what i meant was "low head cap screw".. that just seems to be the type of screw they use for this purpose.
Old Feb 4, 2007 | 07:07 AM
ludesleep's Avatar
Default Re: Need good epoxy or liquid metal (2point2)
how much press do you have on it now? If you want more you can always take a sharp pointed punch and put a few dimples in the bore to raise the surface up a bit.
Old Feb 4, 2007 | 12:52 PM
Bailhatch's Avatar
s1ngle
29
May 9, 2012 03:48 PM
93h22a1vtec
Oct 15, 2006 07:19 AM
mgags7
Sep 28, 2005 06:31 AM
VWkila
May 7, 2005 12:20 PM
