unknown block pieces
i was taking my block apart and two pieces fell off. i have no idea where they go when installing it back in. anyone know where it goes and how to put it back on, please help. thanks.
those are the crankshaft thrust washers. they go in the groove on both sides of the #4 main web (in the block). the grooved side of the bearing faces the crank.
does the two end face the inside of the block or the outstide? does it fit in perfectly? will it not be able to install if you don't put them in? i'll probably just figure it out when i put it on. but thanks
more info will br appreciated.
BoostedH23a1
Feb 8, 2004 05:46 PM
Charlie Moua
Jun 1, 2002 04:39 PM
