Timing belt broke, winter beater, intereference engine?
Old Feb 3, 2007 | 08:49 AM
ubnpast's Avatar
Default Timing belt broke, winter beater, intereference engine?
hey guys, today I picked up a winter beater, it is a 89 prelude si 2.0, automatic, 156k miles. The guy I bought it from said that last month he went to go start the car to let it warm up for a few minutes, went inside, than came back out to find the car shut off. I pulled the cover off, the belt is broken, so my question is do you think I can just have someone throw a belt on and be good? Is this an interference engine?
Thanks for your help.
Old Feb 3, 2007 | 08:55 AM
Hawkze_2.3's Avatar
Default Re: Timing belt broke, winter beater, intereference engine? (ubnpast)
Yes, it's an interference engine, but damage to valves is hit and miss. Put a new belt on and then do a compression test and see if the engine will run.
Old Feb 3, 2007 | 09:01 AM
ubnpast's Avatar
Default Re: Timing belt broke, winter beater, intereference engine? (Hawkze_2.3)
Is there anyway to check compression without getting a belt on? I got the car for $120, and to tell you the truth its in pretty good condition, some rust around the rear fenders.
I have heard since the car was idling that I will most likley be lucky and just be able to toss a belt on, is this true?
Old Feb 3, 2007 | 09:11 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ubnpast &raquo;</TD></TR><TR><TD CLASS="quote">Is there anyway to check compression without getting a belt on? I got the car for $120, and to tell you the truth its in pretty good condition, some rust around the rear fenders.
I have heard since the car was idling that I will most likley be lucky and just be able to toss a belt on, is this true?</TD></TR></TABLE>
Yes, there is a better chance you can save the motor since it was only ideling.
You will have to put the belt on it to check the compression though.
Dlarsson112
Engine Machining & Assembly
Jan 22, 2019 04:38 AM
Em1guy1017
Jul 10, 2017 06:38 AM
(HI)LUDER00
Apr 17, 2013 12:30 PM
R.R
Feb 5, 2011 08:56 AM
callmechad
13
May 26, 2009 07:07 PM
