Can not get timing right on 93 D15B7
Old Feb 2, 2007 | 11:25 PM
kajeno's Avatar
Default Can not get timing right on 93 D15B7
I just replace a crack head with a head that was advertized for 88-95 SOHC non vtec 16 valves. The car start and drive, but I can not get the timing right? Did I get the wrong part? I still have the old cam from the B7. Please help, it is the wife car.
Thanks.
Old Feb 3, 2007 | 08:06 AM
kajeno's Avatar
Default Re: Can not get timing right on 93 D15B7 (kajeno)
Anyone knows. I seach but can find a specific answe.
Old Feb 3, 2007 | 08:27 AM
LABjunkies's Avatar
check the timing marks lined with a crank and make sure you have the cam/distributor pointing to the right spot before turning it over.
Old Feb 3, 2007 | 08:50 AM
SOHCinWA's Avatar
Sounds to me that you have it a tooth off.
Old Feb 5, 2007 | 03:11 PM
kajeno's Avatar
I have the correct timing belt. The car start and drive. I aligned the mark on the crankshaft with the arrow for TDC, and aligned the TDC mark on the camshaft pulley with the cylinder head top surface (both as indicated in the Hanes book). I also bridged the connector to trick the ecu. Now when I used the timing light, I do not match the marks on the crankshaft pulley. But like I am saying the car drive normal with the timing fully advance on the distributor. We even tried moving the belt on way or the other, the best is when we do it following the d15b7 installation as I described before. This makes me wonder if I have the B2 or B1 head. If so can I swap the camshaft with my old B7 camshaft. That is my dilema!!
wagonvanny
Apr 14, 2015 06:12 PM
97gsrki
Nov 15, 2007 11:31 AM
hassan21
Oct 9, 2007 06:35 AM
kajeno
Feb 3, 2007 07:16 PM
civicracer1993
Feb 9, 2003 11:25 AM
