shitty luck leads to this headgasket question
ok guys dont tell me to search i just spent the last half hour doing it and couldnt find what i wanted to know if yall can find it ur bad *** props from me lol ok well heres my thing i got a 81.5 mm comectic head gasket .074" for my b16 i was planning on building for boost well i threw a rod in my damn block today and have a spare ls block laying around and a lsvtec conversion kit also from a past motor and my pistons, havent ordered the rods yet my questions is ... will this headgasket work on a lsvtec everything i found just said they reccomend a ls gasket didnt say not to use the vtec one any help would be apreciated thanks in advance
and also i have the stepped dowels and also have stock dowels dont know if that would make a diffrence
bump
basically i want to know is this headgasket now useless to me unless i buy another vtec block
Well rigth off the bat, you would be running a 81.5mm Headgasket on an 81mm bore block.
I thought you would have to use a 'vtec' head gasket as it has the holes for all the extra oil ways compared to a ls non-vtec head
well actually i would be runinng ross 81.5 mm pistons lol what iam trying to say is my plan was to build the b16 now it has a hole in it and i have a ls block which i will build instead but i want to know if this headgasket i bought before i blew the b16 will work or not with the ls vtec
