ECU/Injectors Messed up?
Old Feb 2, 2007 | 11:46 AM
EKHWhat's Avatar
Default ECU/Injectors Messed up?
I have a OBD1 H22A swapped EK and I'm starting to get a lttle confused with the injector stuff.
I'm running a P72 ECU, and I was told that I could run this ECU on this motor.
I am not sure what kind of injectors I have. I would think the stock injectors.
Rywire wired me up an injector box.
So i'm running Peak and Hold injectors on a ECU that isn't supposed to run P&H injectors?
My car idles kind of funny, but I was thinking it was the IACV or a vaccum leak.
Any suggestions to help me find out what I have?
Old Feb 2, 2007 | 05:38 PM
Blown90hatcH's Avatar
Default Re: ECU/Injectors Messed up? (EKHWhat)
Ecu doesn't care what injectors you are running as long as you are setup properly with the injector or injector/resistor box combo. Ohm out the injectors and tell us what you get.
siguy2k
Aug 19, 2012 09:20 AM
nikolai.
Mar 8, 2006 11:57 AM
aaronhume
Oct 25, 2005 11:52 PM
hypa
May 20, 2003 03:48 AM
MintFlavored
Nov 2, 2002 07:30 PM
