what is a good suspension setup for a 92 eg?
Old Feb 2, 2007 | 07:08 AM
93dabeast's Avatar
Default what is a good suspension setup for a 92 eg?
i want a good setup but i also want to slam my car really low. what should i use to do that? should i use skunk2 coilovers? ground controls? a damper like skunk2? please help
Old Feb 2, 2007 | 07:12 AM
ifIexplode's Avatar
Cut your springs, Weld struts to height
Old Feb 2, 2007 | 07:25 AM
93dabeast's Avatar
come on man be serious
speedhatch's Avatar
Default Re: what is a good suspension setup for a 92 eg? (93dabeast)
DO NOT CUT YOUR SPRINGS!! i think ground contorls are a good choice
Old Feb 2, 2007 | 07:31 AM
jboy08's Avatar
Default Re: what is a good suspension setup for a 92 eg? (speedhatch)
konis w/ ground controls have always been a classic combo. road race-proven too. if you dump it, don't forget the camber kit
a swaybar won't hurt either. itr swaybar (22-23mm) with an asr subframe brace would be good too.
strut bars? you could do maybe a 3 point password jdm front strut bar (carbing or benen if you're baller ) and maybe an em racing combo for the rear.
top it off with a roll cage or roll bar and you'll pretty much have everything you would ever need on the suspension side.
Old Feb 2, 2007 | 07:37 AM
93dabeast's Avatar
thanks man
Lovin_My_E.G[G]
Jun 13, 2009 12:02 PM
HONDAlover369
Suspension & Brakes
10
Jan 5, 2009 08:06 PM
JMelt4
Suspension & Brakes
Feb 2, 2007 01:13 PM
veeDUB
Mar 21, 2002 12:05 PM
jonnyc
Jan 8, 2002 08:49 PM
