Braking Shake (not warped)
Old May 17, 2002 | 01:56 PM
Dawsonb17a's Avatar
New User
Default Braking Shake (not warped)
Okay, this has been something with the car for a long, long time. Whenever I brake from high speeds (50mph+) the steering wheel will shake. I do not know what the cause is. I've noticed this behavior before and after I replaced my rotors and pads a few months ago. It does it every time. I've had my rotors warped before so I know its not the same thing.
I've asked about this on the H-T board before and no one's given me a straight answer. Does anyone know?
Old May 17, 2002 | 02:00 PM
John's Avatar
New User
Default Re: Braking Shake (Dawsonb17a)
Try and balance your rims.
Old May 17, 2002 | 02:38 PM
Dawsonb17a's Avatar
New User
Default Re: Braking Shake (Teken)
Thanks Teken...but I know its not warped rotors. The car brakes in a smooth linear manner, no jerking. The wheels are properly balanced, as I experience this vibration with 2 different sets of wheels/tires. My car is lowered, but after I lowered it I had it aligned and and the camber adjusted.
Anyone else have any ideas?
Old May 17, 2002 | 04:20 PM
Chiovnidca's Avatar
There is a difference in low speed braking and high speed braking when it comes to rotor vibration... I would suggest that you either purchase a micro meter that displays the deflection (rate amount) or have a shop due it for you to make sure..
Teken
A micrometer only measures thickness, And while variations in rotor thickness can cause a vibration, that doesn't come up very often. To properly check for lateral runout, you would need a dial indicator.
One thing I didn't see mentioned is the rear rotors or drums. I don't see it from rear rotors very often, but I have seen it. (They usually have to be in pretty bad shape.) Problems with out of round drums is alot more common.
Old May 17, 2002 | 04:56 PM
jgrotkier's Avatar
what kind of rotors did you put on? I bought some brembo slotted/cross drilled to test them out for the front, and they warped within a few thousand miles
[Modified by jgrotkier, 5:57 PM 5/17/2002]
Old May 18, 2002 | 09:44 AM
Dawsonb17a's Avatar
New User
Default Re: Braking Shake (jgrotkier)
They're stock replacement size Brembo black rotors, no slots or cross drilling. I've got them matched up with Porterfield pads.
Old May 18, 2002 | 10:24 AM
martini's Avatar
Default Re: Braking Shake (Chiovnidca)
but rears wouldn't make the steering shake, it would just cause uneven braking (like a jolting front to back).
My money is on warped fronts, even though you don't think they are.
Old May 18, 2002 | 11:43 AM
Chiovnidca's Avatar
Default Re: Braking Shake (martini)
Yes they can. I see it all the time, especially on Civics.
Old May 18, 2002 | 11:48 AM
Chiovnidca's Avatar
I never said it wasn't the fronts. I was just offering other possibilities. If it was mine, the first thing I would do is turn the front rotors with an on the car brake lathe. That would either fix it or rule that out as a problem.
Old May 18, 2002 | 12:33 PM
Dawsonb17a's Avatar
New User
Ugh, quit saying its rotors. Are you telling me that brand new rotors I put on the car were warped?!? B/c the behavior didn't change after I switched rotors. I can't see warping as a cause, there is no shake or vibration in the pedals whatsoever.
Old May 18, 2002 | 12:37 PM
jgrotkier's Avatar
My front rotors are still warped as a bitch, and I don't feel anything in my pedal, just the steering wheel. Also they are saying it could be your back rotors. If I remember correctly, I could slightly feel shaking in my wheel when my back rotors were warped, but my front were fine.
Old May 19, 2002 | 02:39 PM
martini's Avatar
yeah, that was pointed more towards the original poster, than you..
Old May 19, 2002 | 03:33 PM
Chiovnidca's Avatar
Soory, but you did reply to my post.
LAUREN minter
Suspension & Brakes
Jan 26, 2016 06:53 AM
roc0487
10
Apr 8, 2013 03:32 PM
movingIIshadow
11
Dec 7, 2005 05:36 PM
benSC
Apr 6, 2004 02:45 PM
vicz
May 1, 2003 08:54 AM
