WALBRO 255LPH FUEL PUMP WITH STOCK FUEL PRESSURE REGULATOR.
Old Feb 1, 2007 | 03:28 PM
Initial_drift's Avatar
Default WALBRO 255LPH FUEL PUMP WITH STOCK FUEL PRESSURE REGULATOR.
Im just curious if i can use a walbro 255lph fuel pump and keep all other parts of my fuel system like pressure regulator and injectors stock. I hear something about a return hole. is there a way i can make this bigger? And does anyone know what the stock fuel pump pumps at (liters per hour)?
Old Feb 1, 2007 | 04:42 PM
esedulerp5tenin's Avatar
Default Re: WALBRO 255LPH FUEL PUMP WITH STOCK FUEL PRESSURE REGULATOR. (Initial_drift)
i installed my walbro 255 a couple weeks ago, with the rest of the fuel system being stock.
no problems here
Old Feb 1, 2007 | 04:51 PM
Default Re: WALBRO 255LPH FUEL PUMP WITH STOCK FUEL PRESSURE REGULATOR. (esedulerp5tenin)
did you notice a difference in performance?
Old Feb 1, 2007 | 05:42 PM
A Blue Lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Initial_drift &raquo;</TD></TR><TR><TD CLASS="quote">Im just curious if i can use a walbro 255lph fuel pump and keep all other parts of my fuel system like pressure regulator and injectors stock. I hear something about a return hole. is there a way i can make this bigger? And does anyone know what the stock fuel pump pumps at (liters per hour)? </TD></TR></TABLE>
Why would you? Just curious.
Old Feb 1, 2007 | 08:31 PM
Default Re: WALBRO 255LPH FUEL PUMP WITH STOCK FUEL PRESSURE REGULATOR. (A Blue Lude)
I did it cuz i'm in the middle of my turbo install and wanted to get as much stuff as possible out of the way before hand
and no, there was no power increase because i'm still on stock injectors and fuel pressure.
Old Feb 1, 2007 | 09:03 PM
Oh ok cool. Thanks for your help...yeah I dont have turbo, its just a maintenance mod and since the 190 and the 255 are the same price I just thought, might as well go with the 255 and its also cheaper than buying an OEM replacement.
Old Feb 2, 2007 | 03:49 PM
TTT
schpiel
Jul 10, 2008 01:08 PM
kornerk12
Jan 25, 2006 11:56 AM
B16CRXT
Aug 29, 2004 11:06 PM
speedymon
Nov 10, 2003 04:50 AM
Lei Siew Long
Jan 19, 2002 03:45 PM
