HELP:Wiring Hatch/Cargo/Trunk Dome Light???
Old May 17, 2002 | 01:43 PM
tsr_eg6's Avatar
Default HELP:Wiring Hatch/Cargo/Trunk Dome Light???
hi. i've got a Vx and recently picked up the rear cago dome light from a Si. it just has 2 wires that i assume wire to an always active positive connection and ground. i'm pretty sure i don't have a hatch door sensor that would turn on the light when the door is open. so i'd be happy just flipping the switch up and down to turn it on/off. i looked at the wiring in the wire loom going to all the rear lights and found a match for the positive, i believe. A "Green wire w/ Silver spots". can someone please verify that for me before i go splicing? appreciate any help you can offer. thanks for your time.
Old May 17, 2002 | 05:34 PM
dfoxengr's Avatar
Default Re: HELP:Wiring Hatch/Cargo/Trunk Dome Light??? (tsr_eg6)
Dome...good word for head
Old May 8, 2004 | 03:48 PM
ninety9ex's Avatar
TTT, is wandering the same thing
Old May 8, 2004 | 04:33 PM
hatchdrvr's Avatar
Default Re: HELP:Wiring Hatch/Cargo/Trunk Dome Light??? (ninety5vx)
you can either run a wire from the fuse box for the power and ground one of the wires or you can splice into the domelight's constant power wire (use a test light)located at the driver's side b-pillar and ground one of the wires to the chassis. the later is what I did
Old May 9, 2004 | 04:30 PM
ninety9ex's Avatar
Default Re: (civic_rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rice &raquo;</TD></TR><TR><TD CLASS="quote">keep in mind that these are switched on by the GROUND not the Positive.</TD></TR></TABLE>
I thought that this was already covered
Old May 9, 2004 | 04:46 PM
Kevedge's Avatar
Default Re: (ninety5vx)
Ill have to look at my hatch, but I think thers a plug or something on the tailgate. I do know there is some sort of sensor that triggers a light on your cluster that tells you that your hatch is open, so look around where the glass and hatch meet up, Im sure theres something.
wtemale
Nov 18, 2017 05:08 PM
EH3 JR
Jul 1, 2011 03:04 AM
Shaynepolevault
Lighting
12
May 27, 2008 12:56 AM
adhuot01
May 14, 2008 09:55 AM
mike5809
Honda Motorcycles
Aug 21, 2006 12:03 PM
