code 91 fix, electrical gurus, I NEED YOUR HELP
Old Feb 1, 2007 | 12:25 PM
slowpokecivic's Avatar
Default code 91 fix, electrical gurus, I NEED YOUR HELP
so im using the 10k linear potentiometer that ff-squad said to use. now it says to hook it up to D10 as the +5v. but in the end, it says we need to change it to +2.5v.
how do i do that???
TIA
Old Feb 1, 2007 | 12:52 PM
BignevadaBoB's Avatar
Default Re: code 91 fix, electrical gurus, I NEED YOUR HELP (SLoWpOkECiViC)
use a volt meter to check the voltage and turn the dial on the potentionmetet until you are at 2.5v
Old Feb 1, 2007 | 01:09 PM
Default Re: code 91 fix, electrical gurus, I NEED YOUR HELP (BignevadaBoB)
you mean that long rod?
Old Feb 1, 2007 | 01:35 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLoWpOkECiViC &raquo;</TD></TR><TR><TD CLASS="quote">you mean that long rod?</TD></TR></TABLE>
yes, as you turn it the resistance changes and will in turn change the voltage.
slixxster
Jun 28, 2007 05:33 PM
ek_b16
12
Jan 30, 2005 08:01 PM
gsrcivic619
Nov 21, 2004 08:24 PM
hondaeg95
Aug 20, 2004 10:20 AM
jwitey
Apr 11, 2004 08:54 AM
