swap problem
okay we swapped out my wife's 95 hatch from d15 to b16a jdm, also obd1........everything went smooth and dandy, car starts up normally but we ran into a major problem.
the rear bracket mount wont line up correctly, it should be the right mount becasue all the bolts goes in perfectly but it wont tread thru. its just a few mm short to where it should bolt in. we figured that the motor is tweaked a little, because the alternator pulley is touching the chassy. i called a performance shop and was tld that i might need a new passanger side mount or a rear brakcet, but when i told him its an auto to auto swap he was stuck
so guys i know its auto but its for the wife, if anybody out there who has done this swap (auto to auto jdm b16a) please help......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_junior »</TD></TR><TR><TD CLASS="quote">okay we swapped out my wife's 95 hatch from d15 to b16a jdm, also obd1........everything went smooth and dandy, car starts up normally but we ran into a major problem.
so guys i know its auto but its for the wife, if anybody out there who has done this swap (auto to auto jdm b16a) please help...... </TD></TR></TABLE>
not to make you feel bad, but the first mistake was not bolting up the rear bracket first, then moving on to the other mounts.
as for it being a jdm B16A, if the use the same tranny bracket as the usdm civic use then it should be a straight bolt on. if not, and some how the use the manual bracket on a jdm automatic civic then you will have to change the mount out for a auto to manual mount, if this all makes sense.
BUMP , does anybody know what tranny bracket is used on JDM automatic civic's?
let's help this guy out H-T!
thanks man...we used the same brackets and mounts that came with the engine and the engine came out of a 92 chassy civic (4dr). i'm gonna try and take it to a shop tomorrow and hopefuly everything turns out okay
mario_pic
Mar 10, 2008 04:15 PM
darkracer
Nov 24, 2005 07:25 AM
JBONES
Jun 22, 2005 08:13 PM
