Seat Swap Question
I've looked around and couldn't find anything, so i thought i'd ask. Any kind of tip or advice would be nice...
Basically though, i was given a 94 honda civic sedan, and the seats are super torn up. I want to put in some Integra Leather seats (front and back) would they fit? Direct bolt on? What kind of adjustments would i need to make?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Fronts are complete bolt in. Rears will take minor modifications.</TD></TR></TABLE>
as far as the front seats r concerned u will have to drill one hole for each seat put a bolt thru and tighen as tight as possible i have GSR front seats in my 99 EK the back seat i have no idea good luck
I think it depends on which year Integra you get the seats from, with a 94 Civic 1994–1997 Integra front seats should bolt up perfect. Later/earlier model fronts may not fit as perfect (some modification of the seat frame may be required to make all 4 line up).
Rears I've got no clue on. I've got one of them funny 2-seaters that're based on your generation Civic, which is why I know a little about the fronts.
I know that later generation Civics can't use stock Integra seats without issues, as is apparent from much of this thread. Don't let their problems discourage you though - you have a 92-95 model, not a 96-00.
94-01 Integra seats are direct bolt in for 92-95 Civics.
On a side note, you would need to swap the inner Integra rail with a 96-00 Civic inner rail for Integra seats to bolt in properly.
BB4lude
Apr 30, 2008 10:30 AM
jbell
20
Feb 6, 2005 06:11 PM
