Will EK Coupe and Sedan Axle back fit Hatchback?
Old Feb 1, 2007 | 09:46 AM
JLEK's Avatar
Default Will EK Coupe and Sedan Axle back fit Hatchback?
Researched but can't come up with a clear answer for this one. Will a EK coupe or sedan axle back exhaust fit on a Hatchback? I'm custom make the rest of the piping.
Thanks in advance,
Jonathon
Old Feb 1, 2007 | 12:32 PM
snatch's Avatar
Default Re: Will EK Coupe and Sedan Axle back fit Hatchback? (emperor9)
No. Sedan axle back is too long.
Old Feb 1, 2007 | 12:56 PM
S2k Hybrid's Avatar
You can have the axle back piping cut shorter and rewelded to fit an ek if really want it to work
Old Feb 2, 2007 | 09:56 AM
snatch's Avatar
Default Re: Will EK Coupe and Sedan Axle back fit Hatchback? (S2k Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2k Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">You can have the axle back piping cut shorter and rewelded to fit an ek if really want it to work </TD></TR></TABLE>
That's a lot of work just to use the sedan axle-back.
Old Feb 2, 2007 | 03:20 PM
Brick Top's Avatar
Default Re: Will EK Coupe and Sedan Axle back fit Hatchback? (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">No. Sedan axle back is too long.</TD></TR></TABLE>
Old Feb 14, 2007 | 06:04 AM
JLEK's Avatar
i really want to make the twin loop work. does the hanger need to be adjusted? or is it just the length thats the problem?
Old Feb 14, 2007 | 07:53 AM
MidwestSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emperor9 &raquo;</TD></TR><TR><TD CLASS="quote">i really want to make the twin loop work. does the hanger need to be adjusted? or is it just the length thats the problem?</TD></TR></TABLE>
both
Old Feb 14, 2007 | 08:21 AM
dad0c402's Avatar
if you wanted a twin loop, then buy the muffler and do the custom piping from there and up. It's only an extra foot of piping. If your doing twin loop i'll be interested in the results.
TegoDC5
Oct 17, 2009 10:35 AM
PhA53
May 17, 2008 11:00 AM
slowhonduh93
Nov 24, 2007 09:04 AM
ek_will
11
Dec 2, 2004 05:38 AM
greenf1
Jun 27, 2004 12:59 PM
