b16 swap?
you prob have a D16 now... All d's are sohc, so the dohc B-series engine won't fit your transmission... you'll need the transmission, axles, and a bunch of other stuff
Only cuz im bored im typing this, but seriously search next time theirs SOOOOOOOOOOOOOOOOOOO many topics on this.
b16 engine, depending on ecu ur running and if ur converting it, get either obd2 or obd1 distributor.
b16 transmission, must be hydrolic transmission.
**** linkage from 94-97 delsol vtec model/94-01integra, or 99-2000 civic si, but im not positive on the si but i believe it should work.
b16 clutch
b-series axles
3 piece mount kit from either of these companies
http://www.hasport.com
http://www.passwordjdm.com
http://www.innovativemounts.com
any of those sell kits for your swap.
b16 halfshaft, shaft allows your driver side axle to plug into the transmission.
b16 obd2 ecu. or obd1 ecu with a obd2-obd1 conversion harness.
b16 starter
Transmission,clutch, and other assorted bolts, if your swap isnt together.
and about 2-400 extra dollars for random **** here and there that u will run into.
b16 clutch
b-series axles
b16 starter
hondatuner020
12
Dec 27, 2007 06:32 AM
camera obscura
11
Mar 27, 2003 06:40 PM
